I am using an A-SATA dock with a WD green 3.0TB for data storing in a Linux Mint system.
While a .rar file was unzipping we had a powercut. The UPS didn't work (battery failure)
Bummer!
Now the disk is visible in Disks
but shows this message when attempting to access in Dolphin:
I booted into Windows but while the disk is visible as disk0 it has no drive letter so I cannot chkdsk it.
here is the testdisk log (run in Linux):
Mon Mar 3 22:14:46 2014
TestDisk 7.0-WIP, Data Recovery Utility, January 2014
OS: Linux, kernel 3.8.0-35-generic (#50-Ubuntu SMP Tue Dec 3 01:25:33 UTC 2013) i686
Compiler: GCC 4.4
Compilation date: 2014-02-02T16:32:51
/dev/sda: size 3907029168 sectors
/dev/sda: user_max 3907029168 sectors
/dev/sda: native_max 3907029168 sectors
/dev/sda: dco 3907029168 sectors
/dev/sdb: size 1953525168 sectors
/dev/sdb: user_max 1953525168 sectors
/dev/sdb: dco 1953525168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 1953525168 sectors
/dev/sdc: user_max 1953525168 sectors
/dev/sdc: native_max 1953525168 sectors
/dev/sdc: dco 1953525168 sectors
/dev/sdd: LBA, HPA, LBA48, DCO support
/dev/sdd: size 3907029168 sectors
/dev/sdd: user_max 3907029168 sectors
/dev/sdd: native_max 3907029168 sectors
/dev/sdd: dco 3907029168 sectors
/dev/sde: LBA, HPA, LBA48, DCO support
/dev/sde: size 5860533168 sectors
/dev/sde: user_max 5860533168 sectors
/dev/sde: native_max 5860533168 sectors
/dev/sde: dco 5860533168 sectors
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARS-00MVWB0, S/N:WD-WCAZA3250793, FW:51.0AB51
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000528AS, S/N:9VP0FJ87, FW:CC34
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EADS-00P8B0, S/N:WD-WMAVU0012073, FW:01.00A01
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EZRX-00DC0B0, S/N:WD-WMC301082059, FW:80.00A80
Disk /dev/sde - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00D8PB0, S/N:WD-WCC4N0050041, FW:80.00A80
Disk /dev/sde - 3000 GB / 2794 GiB - WDC WD30EZRX-00D8PB0
Analyse Disk /dev/sde - 3000 GB / 2794 GiB - CHS 364801 255 63
Geometry from i386 MBR: head=117 sector=51
BAD_RS LBA=6579571 5870008
check_part_i386 1 type 70: no test
BAD_RS LBA=1953251627 4634015
check_part_i386 2 type 43: no test
BAD_RS LBA=225735265 4634074
check_part_i386 3 type 72: no test
1 * DiskSecure MB 409 142 41 119790 20 38 1917848077
Bad relative sector.
2 * Sys=43 121584 74 6 234785 103 28 1818575915
3 * Sys=72 14051 94 29 14051 94 38 10
BAD_RS LBA=4068185308 2973444
FAT16 LBA 253232 209 62 469999 122 28 3482356341
This partition ends after the disk limits. (start=4068185308, size=3482356341, end=3255574352, disk end=1565565872)
BAD_RS LBA=1030027564 15283591
FAT16 >32M 64116 63 56 203649 167 53 2241604195
BAD_RS LBA=400790833 4654730
FAT16 <32M 559646 197 25 756993 253 26 3170383085
This partition ends after the disk limits. (start=400790833, size=3170383085, end=3571173917, disk end=1565565872)
The harddisk (3000 GB / 2794 GiB) seems too small! (< 6226 GB / 5798 GiB)
L FAT16 >32M 64116 63 56 203649 167 53 2241604195
interface_load
1 P FAT16 >32M 64116 63 56 203649 167 53 2241604195
Can you please help me restore this disk?
