I can't thank you enough.
iraklis1957
#1 Post by iraklis1957 »
Dear sirs,
As I mentioned in the title,I truly can't thank you enough.Thanks to you a completely useless HP G72 laptop now does what it was intented to.I want to share what I did hoping it will help others.
I was trying to boot to a damaged, by my 10year old nethew,laptop.I don't have any professional experience but I discovered that by following someone else's instructions you can sometimes surpass your skills.After an extensive search describing my problems I found your step by step guide.I followed it to the letter but I hesitated when after deeper search I had to mark as deleted 298 gb of the 320 gb hdd and boot at HP recovery partition.I shouldn't have.I booted there the laptop began the recovery process and everything is solved.Again thank you very much.
Best regards,
