Phone sdcard and external sdcard missing several files
TestdiskForTheWin
#1 Post by TestdiskForTheWin »
Ive tried most of things for my very specific situation in Testdisk but they didnt help except a few things I havent tried because I dont know if and how do them.
What happened:
I had removable sdcard in phone and plugged phone into Pc via usb cable to charge phone and reverse tether(share PC's internet connection with phone).
The storages are always automounted even if I havent used Mount USB Storage in Android.For some reason (I dont know why) I used the option.After that I used unmount usb storage and pulled cable because it was taking very long and I thought that it is safe because the storage is not doing anything.
I also only selected eject removable media for one storage only (I use Lubuntu 14.04 Linux Operating System)
What is now:
Most of the files are gone and the storages have more free space.Ive not used the phone at all yet (for two weeks) to not overwrite any file.I need to use phone for work but asking around on multitude of forums have not helped me yet.
phone storage
In the Boot menu I get the following warnings:
     Disk /dev/sdb - 12 GB / 11 GiB - CHS 1502 255 63
       P FAT32                    0   0  1  1502  63 33   24133632 [NO NAME]
    Warning: number of heads/cylinder mismatches 4 (FAT) != 255 (HD)
    Warning: number of sectors per track mismatches 16 (FAT) != 63 (HD)
    OK
    OK
    Sectors are identical.
After choosing Rebuild BS (Bootsector) I get warnings:
    FAT : 32
    cluster_size 64 64
    reserved     32 32
    total_sect   24133632 24133632
    fat32_length 2946 2946
    root_cluster 2 2
    free_count   uninitialised 375052
    next_free    uninitialised 514
**After the repair boot sector is finished nothing changes:I can still copy the same amount of files as before (almost nothing)**
removable sdcard
Disk /dev/sdc - 15 GB / 14 GiB - CHS 1909 255 63
   P FAT32                    0   0  1  1909  43 54   30670848 [NO NAME]
OK
OK
First sectors (Boot code and partition information) are not identical.
FAT : 32
cluster_size 64 64
reserved     704 704
total_sect   30670848 30670848
fat32_length 3744 3744
root_cluster 2 2
free_count   uninitialised 448822
next_free    uninitialised 11
Failed copy file attempts:
When using copy, all files that: Testdisk says are 32768 in size (there are lots of these files and they are not 32768 in size) fail to be copied and Testdisk immediately says
Copy done! 0 ok, 0 failed .Several other files are 0 in size according to Testdisk and I get the same message.
When I select copy 123Folder Testdisk always copies the 123Folder but with the contents of all files it sees.(For example the copied 123Folder will contain empty 123Folder and all other files Testdisk sees on storage) This issue is for some other folders too which have 0 in size according to Testdisk
Copied folder has exact same size and filename but it is an .exe so I cant access it.
Music folder (contains .flac) and TitaniumkBackup is zero in size according to Testdisk so I tried Photorec.But all files except 4 flac are corrupt.
Re: Phone sdcard and external sdcard missing several files
Can you try PhotoRec 6.14 or 7.0-WIP ?
After selecting the partition, choose [Search] and [Whole] instead of [Free].
TestdiskForTheWin
#3 Post by TestdiskForTheWin »
Thanks very much for your reply cgrenier.
I have used Photorec 7.0 WIP and used Whole.Photorec recovered most files Testdisk couldn't recover.
Unfortunately only 4 flac files out of about 56 aren't corrupted (I'm keeping the corrupted flac in hope that they can be fixed)
and most of tar jar zip wav png flac that Ive tried to open are corrupted.
(Im only after flac files and tar files unless I can restore filenames and directory structure)
Photorec hasn't finished restoring removable sdcard yet but most of files are corrupted.
Thanks again cgrenier.
TestdiskForTheWin
#4 Post by TestdiskForTheWin »
Please help!
#5 Post by cgrenier »
If the original filesystem was fragmented, all files can't be recovered successfully. Sorry.
