the partition found doesn't contains data
dgt4
#1 Post by dgt4 »
I want to know how to proceed when the partition lost and found doesn't contains my data
I lost 1 of the three partitions of the hd. the other two are ok.
after a deep search, this are the results:
this is the partition wich in need to restore, or recover some data from it.
I listed the files in the last two partitions whit the results shown in the screen capture sequence.
how must I proceed for recovering the data in this partition, if there is any way
thank you all
Daniel
Re: the partition found doesn't contains data
What do you mean by "lost the partition" ?
Has the partition been corrupted and after a chkdsk, no files are listed anymore ?
dgt4
#3 Post by dgt4 »
I use the HD as external disk.
windows shows the three partitions, but cannot read the last one. I can't run chckdisk with this partition. when I attempt to access, the console and the explorer returns "el parámetro no es correcto"(sorry, I write from spain... somethin like "the parameter or value is wrong or incorrect")
Althought I can see the partition as a drive, i can't read it now. This is why i used testdisk for fixing it.
Any idea?
