From "UNALLOCATED" to "RAW"
p3voices
#1 Post by p3voices »
I have used Testdisk as outlined in your instructions to recover a disk that appears as UNALLOCATED. After a Deep Scan, I selected the option to write a new Partition.
Now the disk appears as RAW.
Am I working backwards and making the matter worse?
I need to recover my email from this disc.
Can I reverse the write of the new Partition?
** Please help! ** :( :o :shock:
LOG FILES:
Initial Use of Test Disk (disk as UNALLOCATED):
Thu Apr 17 05:11:37 2014
TestDisk 7.0-WIP, Data Recovery Utility, March 2014
Compilation date: 2014-04-15T22:56:54
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000097185792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\P:)=1000096137216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\W:)=104857600
filewin32_getfilesize(\\.\X:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\X:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\X:
filewin32_getfilesize(\\.\Y:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\Y:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\Y:
filewin32_getfilesize(\\.\Z:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\Z:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\Z:
Disk /dev/sda - 1000 GB / 931 GiB - CHS 129201 240 63, sector size=512 - WDC WD10EARS-00Y5B1, S/N:2020202057202d44435756414c35373431313631, FW:80.00A80
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EZRX-00DC0B0, S/N:2020202057202d444d5731433254323333313633, FW:80.00A80
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARS-00MVWB0, S/N:2020202057202d444d575a413441343332353035, FW:51.0AB51
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00DC0B0, S/N:2020202057202d44435731433054393130393239, FW:80.00A80
Disk /dev/sde - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EADS-22M2B0, S/N:2020202057202d44435756413335393438303330, FW:01.00A01
Disk /dev/sdf - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST925041 0AS, FW:0200
Disk /dev/sdf - 250 GB / 232 GiB - ST925041 0AS
Analyse Disk /dev/sdf - 250 GB / 232 GiB - CHS 30401 255 63
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 0/32/33
filesystem size 488392704
mftmirr_lcn 2
HPFS - NTFS 0 32 33 30401 42 41 488392704
NTFS, blocksize=4096, 250 GB / 232 GiB
file_pread(9,2,buffer,488398848(30401/107/43)) lseek err Invalid argument
file_pread(9,1,buffer,488398848(30401/107/43)) lseek err Invalid argument
file_pread(9,8,buffer,488397184(30401/81/17)) lseek err Invalid argument
file_pread(9,1,buffer,488397184(30401/81/17)) lseek err Invalid argument
file_pread(9,8,buffer,488397312(30401/83/19)) lseek err Invalid argument
file_pread(9,8,buffer,488397440(30401/85/21)) lseek err Invalid argument
file_pread(9,8,buffer,488397568(30401/87/23)) lseek err Invalid argument
file_pread(9,8,buffer,488397696(30401/89/25)) lseek err Invalid argument
file_pread(9,8,buffer,488397824(30401/91/27)) lseek err Invalid argument
file_pread(9,8,buffer,488397952(30401/93/29)) lseek err Invalid argument
file_pread(9,8,buffer,488398080(30401/95/31)) lseek err Invalid argument
file_pread(9,8,buffer,488398208(30401/97/33)) lseek err Invalid argument
file_pread(9,8,buffer,488398336(30401/99/35)) lseek err Invalid argument
file_pread(9,8,buffer,488398464(30401/101/37)) lseek err Invalid argument
file_pread(9,8,buffer,488398592(30401/103/39)) lseek err Invalid argument
file_pread(9,8,buffer,488398720(30401/105/41)) lseek err Invalid argument
file_pread(9,1,buffer,488398847(30401/107/42)) lseek err Invalid argument
file_pread(9,14,buffer,488398849(30401/107/44)) lseek err Invalid argument
file_pread(9,3,buffer,488398863(30401/107/58)) lseek err Invalid argument
file_pread(9,3,buffer,488398910(30401/108/42)) lseek err Invalid argument
file_pread(9,8,buffer,488398926(30401/108/58)) lseek err Invalid argument
file_pread(9,11,buffer,488398973(30401/109/42)) lseek err Invalid argument
file_pread(9,2,buffer,488400895(30401/140/11)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 30401 42 41 488392704
Not an exFAT boot sector.
1 P HPFS - NTFS 0 32 33 30401 42 41 488392704
NTFS at 0/32/33
mftmirr_lcn 2
NTFS at 30401/42/41
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 250 GB / 232 GiB
1 * HPFS - NTFS 0 32 33 30401 42 41 488392704
write!
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Second Use of Test Disk (disk as RAW):
Thu Apr 17 06:51:55 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=250059350016
file_pread(4,1,buffer,1953534239(129201/239/63)) lseek err Invalid argument
file_pread(5,1,buffer,3907040129(243201/254/63)) lseek err Invalid argument
file_pread(6,1,buffer,1953536129(121601/254/63)) lseek err Invalid argument
file_pread(7,1,buffer,3907040129(243201/254/63)) lseek err Invalid argument
file_pread(8,1,buffer,1565574943(387601/239/63)) lseek err Invalid argument
file_pread(9,1,buffer,488408129(30401/254/63)) lseek err Invalid argument
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EADS-22M2B0, S/N:2020202057202d44435756413335393438303330, FW:01.00A01
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARS-00MVWB0, S/N:2020202057202d444d575a413441343332353035, FW:51.0AB51
Disk /dev/sde - 3000 GB / 2794 GiB - CHS 387601 240 63, sector size=512 - WDC WD30EZRX-00DC0B0, S/N:2020202057202d44435731433054393130393239, FW:80.00A80
Disk /dev/sdh - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST925041 0AS, FW:0200
Disk /dev/sdh - 250 GB / 232 GiB - ST925041 0AS
Analyse Disk /dev/sdh - 250 GB / 232 GiB - CHS 30401 255 63
NTFS at 0/32/33
Computes LBA from CHS for Disk /dev/sdh - 250 GB / 232 GiB - CHS 30402 255 63
search_vista_part: 1
NTFS at 0/32/33
mftmirr_lcn 2
NTFS, 250 GB / 232 GiB
file_pread(9,7,buffer,488398849(30401/107/44)) lseek err Invalid argument
file_pread(9,8,buffer,488398848(30401/107/43)) lseek err Invalid argument
file_pread(9,8,buffer,488398856(30401/107/51)) lseek err Invalid argument
file_pread(9,3,buffer,488398864(30401/107/59)) lseek err Invalid argument
file_pread(9,3,buffer,488398911(30401/108/43)) lseek err Invalid argument
file_pread(9,8,buffer,488398927(30401/108/59)) lseek err Invalid argument
file_pread(9,11,buffer,488398974(30401/109/43)) lseek err Invalid argument
file_pread(9,2,buffer,488400896(30401/140/12)) lseek err Invalid argument
p3voices
Re: From "UNALLOCATED" to "RAW"
#2 Post by p3voices »
Any advice or help to offer?
p3voices
#3 Post by p3voices »
cgrenier, could you please give me some assistance? :o
I am at a loss ... and need my email back up and running. :?
Using TestDisk 6.14 or 7.0-WIP, in the Advanced menu, select the partition and choose Boot,
- if available, choose BackupBS and confirm
- try List
Please post the new log if it doesn't work.
