The Harddisk seems too small
chumps52
#1 Post by chumps52 »
I'm new to this.
My PC consists of two drives:
A 250GB SSD for Programs and the OS, and a 1TB WD HDD for Documents etc.
I booted up my PC this morning and the HDD wasn't functioning (There was a powercut last night, I assume it interrupted something).
Disk management shows this: Image
I ran an analysis on TestDisk, which at around 60% came up with this: Image
This is the full log as it appears in testdisk.log:
Tue Apr 22 09:58:11 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=145200513024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 840 EVO 250GB, S/N:31534244534e4641313233393231205620202020, FW:EXT0BB6Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EALX-009BA0, S/N:2020202057202d444d5754413052373333393139, FW:15.01H15
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10EALX-009BA0
test_FAT()
 1 * FAT16 >32M               0  32 33 121601  25 24 1953519616
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
Invalid FAT boot sector
Does anyone know what to do? :/
I need these files back...
Thanks in advance, and sorry if this was badly worded!
Re: The Harddisk seems too small
Run TestDisk, Boot, select the "FAT" partition, use 't' to change its type to 7 (NTFS), Boot,
if the option is listed, choose BackupBS, confirm, Analyse, Quick Search, if your NTFS partition is listed, choose Write, confirm, Quit
Please post the new log file if you have problems.
Mapy58
#3 Post by Mapy58 »
J'ai le même problème, mais je n'arrive pas à retrouver dans Testdisk vos indications.
Cordialement,
Mapy58 wrote:Bonjour,
Cordialement,
Merci d'utiliser le forum en français ou bien postez en anglais.
Please use the French forum instead and provide all the information related to your problem.
