Dear Grenier,
after trying to recover GRUB with "Boot Repair Disk", one HD (without systems partition, contaning 2 NTFS partitions) was damaged, and the GPT e and one NTFS partition could not be found anymore, until now.
I ran testdisk -> Create -> Drive E: (the missing NTFS partition) -> Proceed -> Intel / PC partition -> Analyse -> Search and Deep Search after.
I couldn't recover the NTFS partition instead.
LOG file:
Tue Apr 22 18:16:27 2014
Compiler: GCC 4.7, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=16043212800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119478943744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2147483648000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=852972535808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=500104691712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=536661196800
filewin32_getfilesize(\\.\I:) GetFileSize err Função incorreta.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Função incorreta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=16041115648
filewin32_getfilesize(\\.\K:) GetFileSize err Função incorreta.
filewin32_setfilepointer(\\.\K:) SetFilePointer err Função incorreta.
Disk \\.\PhysicalDrive0 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive5 - 16 GB / 14 GiB - CHS 1950 255 63, sector size=512
Drive C: - 119 GB / 111 GiB - CHS 14525 255 63, sector size=512
Drive D: - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive E: - 2147 GB / 2000 GiB - CHS 261083 255 63, sector size=512
Drive F: - 852 GB / 794 GiB - CHS 103701 255 63, sector size=512
Drive G: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
Drive H: - 536 GB / 499 GiB - CHS 65245 255 63, sector size=512
Drive J: - 16 GB / 14 GiB - CHS 1950 255 63, sector size=512
Analyse Drive E: - 2147 GB / 2000 GiB - CHS 261083 255 63
BAD_RS LBA=1535450125 4028305
FAT12 362926 178 18 555980 150 41 3101410770
This partition ends after the disk limits. (start=1535450125, size=3101410770, end=341893598, disk end=4194304000)
BAD_RS LBA=3541218466 4289729
FAT12 220430 166 59 395880 144 31 2818602837
This partition ends after the disk limits. (start=3541218466, size=2818602837, end=2064854006, disk end=4194304000)
NTFS at 261083/88/61
filesystem size 4194304000
mftmirr_lcn 2
HPFS - NTFS 0 0 1 261083 88 61 4194304000
NTFS found using backup sector, blocksize=4096, 2147 GB / 2000 GiB
Partition not added.
The harddisk (2147 GB / 2000 GiB) seems too small! (< 4573 GB / 4259 GiB)
interface_load
mftmirr_lcn 2
Store new MBR code
Please, i need your help to recover the partition. Sorry for the english.
Thanks.
NTFS partition lost on a 3TB disk with EFI/GPT partition
danilovcorrea
Re: NTFS partition lost on a 3TB disk with EFI/GPT partition
What is the problem ? Missing partition, wrong partition size, corrupted filesystem ?
If a partition is missing or has a wrong size (ie 2 TB instead of 3 TB),
you must select the PhysicalDrive, not a drive letter. Please post the new log file if you are in this case.
danilovcorrea
Hi Grenier,
the problem is a lost NTFS partition, there is a RAW partition instead:
There are three partitions on this disk: GPT reserved partition, Drive E: (NTFS before, and RAW now), and Drive F: "Data 3" (NTFS, working fine):
As recomended, i ran the PhysicalDisk option:
LOG File:
Wed Apr 23 16:36:51 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=1010827264
Drive I: - 1010 MB / 964 MiB - CHS 241 64 32, sector size=2048
Analyse Disk \\.\PhysicalDrive0 - 3000 GB / 2794 GiB - CHS 364801 255 63
BAD_RS LBA=4144590965 2156993
FAT16 >32M 257988 218 12 456562 73 21 3190082185
This partition ends after the disk limits. (start=4144590965, size=3190082185, end=3039705853, disk end=1565565872)
BAD_RS LBA=1535714317 4028305
FAT12 362943 36 51 555997 9 11 3101410770
This partition ends after the disk limits. (start=1535714317, size=3101410770, end=342157790, disk end=1565565872)
BAD_RS LBA=3541482658 4289729
FAT12 220447 25 29 395897 3 1 2818602837
This partition ends after the disk limits. (start=3541482658, size=2818602837, end=2065118198, disk end=1565565872)
NTFS at 261099/202/32
filesystem size 1665961984
mftmirr_lcn 2
HPFS - NTFS 261099 202 32 364801 33 32 1665961984 [DATA 3]
NTFS, blocksize=4096, 852 GB / 794 GiB
The harddisk (3000 GB / 2794 GiB) seems too small! (< 4573 GB / 4259 GiB)
* HPFS - NTFS 261099 202 32 364801 33 32 1665961984 [DATA 3]
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 261099/202/31
mftmirr_lcn 2
HPFS - NTFS 16 113 34 261099 202 31 4194304000
mftmirr_lcn 2
NTFS at 364801/33/32
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 852 GB / 794 GiB
NTFS at 364801/66/1
filesystem size 5860268032
mftmirr_lcn 2
HPFS - NTFS 16 113 34 364801 66 1 5860268032
NTFS found using backup sector, blocksize=4096, 3000 GB / 2794 GiB
Not an exFAT boot sector.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 23-Apr-2014 18:43 .
5 dr-xr-xr-x 0 0 0 23-Apr-2014 18:43 ..
35 dr-xr-xr-x 0 0 0 11-Feb-2014 07:52 $RECYCLE.BIN
237736 dr-xr-xr-x 0 0 0 13-Apr-2014 19:45 ADMIN-PC
26093 dr-xr-xr-x 0 0 0 21-Dec-2013 12:19 BACKUPS
143 dr-xr-xr-x 0 0 0 20-Dec-2013 15:39 DOCUMENTOS
10916 dr-xr-xr-x 0 0 0 29-Dec-2013 12:01 F$MFT has invalid magic.
OTOS
42 dr-xr-xr-x 0 0 0 20-Dec-2013 15:36 LIVROS
38 dr-xr-xr-x 0 0 0 22-Apr-2014 16:19 System Volume Information
49 dr-xr-xr-x 0 0 0 20-Dec-2013 15:36 VIDEOS
237734 -r--r--r-- 0 0 528 17-Jan-2014 03:32 MediaID.bin
How can i recover the lost NTFS partition?
Thank you for the help.
LOG File:
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
NTFS at 364801/66/1
mftmirr_lcn 2
OTOS
danilovcorrea
Hi Grenier,
I've read the step by step tutorial, but i still don't know how to recover the NTFS damaged partition.
I really appreciate your help. Thanks.
Run TestDisk, Advanced, select your 2TB partition, Boot,
- if the NTFS boot sector is corrupted and the backup is ok, choose BackupBS and confirm,
- if both are bad, choose RebuildBS, List and if you can see your files, choose Write and confirm
Quit and reboot
Please post the testdisk.log file if you have problems.
Quit and reboot
danilovcorrea
Hi Grenier,
the damaged NTFS partition (Drive E:) is a non bootable partition (contains only data).
As recommended i ran the testdisk commands that you posted:
"No partition available"
LOG File:
Sun Apr 27 09:14:07 2014
TestDisk 7.0-WIP, Data Recovery Utility, April 2014
Compiler: GCC 4.8, MinGW 3.11
Compilation date: Apr 20 2014 11:45:25
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=16041115648
Drive M: - 16 GB / 14 GiB - CHS 1950 255 63, sector size=512
LOG File:
danilovcorrea
Should i choose the EFI / GPT partition?
danilovcorrea
There is a way to see the archives list at this ntfs damaged partition?
Please select the PhysicalDrive and not E:
Even if the partition is not bootable, the first sector is called a boot sector.
Please follow my previous instructions
