Recover Partition endmark 0xAA55, fail to recover
pirateskiller
#1 Post by pirateskiller »
Hi there,
I wondering any way to recover this pendrive.. I'd tried photorec but some files were recovered some were not.. is there any way to recover its partitions?
Errors I got were:-
1) endmark 0xAA55
2) the harddisk seems to small
here I attach the teskdisk.log
Wed Apr 23 21:10:45 2014
Compiler: GCC 4.7, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=4007624704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=199229440000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=300323700736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500073234432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=4007624704
filewin32_getfilesize(\\.\Z:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\Z:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\Z:
Disk \\.\PhysicalDrive0 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 4007 MB / 3821 MiB - CHS 487 255 63, sector size=512
Drive C: - 199 GB / 185 GiB - CHS 24221 255 63, sector size=512
Drive D: - 300 GB / 279 GiB - CHS 36512 255 63, sector size=512
Drive E: - 500 GB / 465 GiB - CHS 976705536 1 1, sector size=512
Drive F: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive4 - 4007 MB / 3821 MiB - CHS 487 255 63
FAT32 at 1/135/7
FAT1 : 1128-8755
FAT2 : 8756-16383
start_rootdir : 16384 root cluster : 2
Data : 16384-7827391
sectors : 7827392
cluster_size : 8
no_of_cluster : 976376 (2 - 976377)
fat_length 7628 calculated 7628
FAT differs, FAT sectors=0-16/7628
FAT32 at 1/135/7
     FAT32                    1 135  7   488 194 26    7827392 [NO NAME]
     FAT32, blocksize=4096, 4007 MB / 3821 MiB
This partition ends after the disk limits. (start=24576, size=7827392, end=7851967, disk end=7827392)
FAT32 at 100/246/19
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 100/246/19
     FAT32                  100 246 19   588  50 38    7827392 [NO NAME]
This partition ends after the disk limits. (start=1622016, size=7827392, end=9449407, disk end=7827392)
The harddisk (4007 MB / 3821 MiB) seems too small! (< 4838 MB / 4613 MiB)
FAT32 at 1/135/7
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 1/135/7
FAT32 at 1/135/13
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 1/135/13
FAT32 at 100/246/19
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 100/246/19
FAT32 at 100/246/25
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 100/246/25
Store new MBR code
Thanks...
Re: Recover Partition endmark 0xAA55, fail to recover
Run TestDisk, use the Geometry menu to set 500 cylinders, Analyse, Quick Search, Deeper Search, try to list the files of your partition. If it works,
- set this partition as *(bootable) or P(rimary)
- on next screen, choose Write, confirm.
- if asked, choose BackupBS and confirm
- Quit
pirateskiller
#3 Post by pirateskiller »
thanks for your reply..
Seems like I cannot list the files, it turned out program stop working..
I did changed to 500 and write it.. but I had drives as attached picture..
seems like it didnt show to backupBS.. did I did something wrong? :o
Code after I reboot my system..
Thu Apr 24 00:35:52 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4007624704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=4007657472
Disk \\.\PhysicalDrive1 - 4007 MB / 3821 MiB - CHS 487 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive E: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive H: - 4007 MB / 3822 MiB - CHS 487 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive1 - 4007 MB / 3821 MiB - CHS 487 255 63
Geometry from i386 MBR: head=196 sector=27
FAT32 at 1/135/7
Info: size boot_sector 7827392, partition 7827456
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
 1 * FAT32                    1 135  7   488 195 27    7827456 [NO NAME]
Warning: Bad ending cylinder (CHS and LBA don't match)
FAT32 at 1/135/7
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 1/135/7
FAT32 at 100/246/19
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 100/246/19
FAT32 at 1/135/7
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 1/135/7
FAT32 at 1/135/13
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 1/135/13
FAT32 at 100/246/19
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 100/246/19
FAT32 at 100/246/25
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
FAT32 at 100/246/25
New geometry
Disk \\.\PhysicalDrive1 - 4112 MB / 3922 MiB - CHS 500 255 63 sector_size=512
Analyse Disk \\.\PhysicalDrive1 - 4112 MB / 3922 MiB - CHS 500 255 63
FAT32 at 1/135/7
FAT1 : 1128-8755
FAT2 : 8756-16383
sectors : 7827392
cluster_size : 8
Debug error
Lets try something else. Run PhotoRec, select Whole Disk and start a recovery. Original filenames won't be recovered but at least you should have your data back.
