Data recovered, but disc doesn't show up in windows
Hypersomnia
#1 Post by Hypersomnia »
I recovered the data, at least i think i have because the raid0 array with the data doesn't shows up in Windows.
Let me start with the problem and what I did to fix it .
I have a RAID0 array containing 2X 1TB samsung HD103SJ and one of the disks fel out of the raid config
This array contained my Windows partition (80GB) and a 2nd parition for everything else.
SO i reinstalled windows on a other disk; removed and redid the Raid0 array exactly and ran Testdisk
all files showed up again :_)
Just in case i copyed the most important files to a external disc.
Afterwarts I recovered it like this:
TestDisk 7.0-WIP, Data Recovery Utility, April 2014
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
* HPFS - NTFS 0 32 33 12 223 19 204800
P HPFS - NTFS 12 223 20 10456 20 60 167770112
> HPFS - NTFS 10456 1 1 243200 254 63 3739048362
Enter: to continue
did i do something wrong with the * P ? Or is it something else?
Re: Data recovered, but disc doesn't show up in windows
Set the last partition as P(rimary). On next screen, choose Write, confirm, Quit
Restart your computer.
You may have to use Windows Disk Manager to assign a drive letter to each partition.
Hypersomnia
#3 Post by Hypersomnia »
if I change the last partition also to primary the programm says the STRUCTURE: BAD. What do i need to do about that?
Hypersomnia
#4 Post by Hypersomnia »
This is the situation in my disk atm
'Schijf 0" is the disk in question
there are 3 partitions, 1:reserved by system; 2: Windows 7 64bit; 3: Software
I can get only 2 out of 3
the folowing combinations work:
- reserved by system(*) & windows 7 64 bit partition(P)
- reserved by system(*) & Software(P)
I can not set windows 7 64 bit and Software partition as primary. Even if i set win 7 partition as primary bootable the software partition can't be set to something else
