Filesystem corrupted, partition OK
paulkinzelman
#1 Post by paulkinzelman »
My 1TB NTFS drive (not the boot disk) all of a sudden is inaccessible, wIndows wants to format it.
I ran testdisk on it and the partition seems OK, but the filesystem is gone:
Drive E: - 1000 GB / 931 GiB - CHS 15200 255 63
> HPFS - NTFS 0 4 5 15200 35 3 244189952
HPFS - NTFS 0 4 5 15200 35 4 244189952
Is it possible to recover the file system somehow and retrieve filenames and directories?
TIA!
The log file says:
TestDisk 7.0-WIP, Data Recovery Utility, April 2014
Compilation date: 2014-04-28T11:22:53
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=101948850176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=130970288128
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000204886016
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - SanDisk SD6SN1M256G1002, S/N:133910400919, FW:X231202
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - TOSHIBA DT01ACA100, S/N:152D20337A0C
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - TOSHIBA DT01ACA100, S/N:152D20337A0C
Drive E: - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - TOSHIBA DT01ACA100, S/N:152D20337A0C
Drive E: - 1000 GB / 931 GiB - TOSHIBA DT01ACA100
Analyse Drive E: - 1000 GB / 931 GiB - CHS 15200 255 63
Invalid NTFS or EXFAT boot
1 P HPFS - NTFS 0 32 33 121601 25 24 1953519616
NTFS signature is missing.
NTFS at 0/4/5
filesystem size 1953519616
mftmirr_lcn 2
* HPFS - NTFS 0 4 5 15200 35 3 244189952
Not an exFAT boot sector.
Re: Filesystem corrupted, partition OK
Please use the PhysicalDrive, not the drive letter.
paulkinzelman
#3 Post by paulkinzelman »
Sorry, I didn't understand the distinction between Phys drive and logical drive.
Below I've posted the log resulting from the physical drive.
I tried running the GetDataBack tool (evaluation) and I get what looks like a
significant portion of the file tree structure and filenames look correct, but
all the files seem to be corrupted.
On the other hand, I run your photorec tool and I get no filenames, but I
do seem to recover actual in-tact files (via spot-check), but no valid file names
and no structure. The other problem is that after 2 days of running, it's
estimating that it'll take about 2 months to process the entire disk. :-(
It seems like there should be a way to get files back *and* their filenames?
Even the names without the structure would be a help.
Fri May 2 07:25:10 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Y:)=500105217024
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63 (RO), sector size=512 - ST350083 0AS, S/N:152D20329000
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - TOSHIBA DT01ACA100
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 15200 255 63
NTFS at 0/4/5
mftmirr_lcn 2
1 * HPFS - NTFS 0 4 5 15200 35 3 244189952
It looks like your disk is using 4096 bytes sector (4k) but was previously using 512 bytes sectors.
Run TestDisk, after QUick Search, choose Write and confirm, go in Advanced, select the NTFS partition, choose Boot, RebuildBS, List. If you can see your files, choose Write and confirm. Quit and reboot
theboytony
#5 Post by theboytony »
What do you do if you get to this point but when going to list no files come up is just gives a filesystem error
paulkinzelman
#6 Post by paulkinzelman »
I think I did what you suggested, here are my notes from what I tried. However it still says bytes per sector mismatch. Shouldn't that warning go away? Did I not follow your instructions correctly?
TIA!
TestDisk:
Selected PhysicalDrive1 | proceed
Selected Intel partition
Selected Analyze | Quick Search
Found Partition HPFS - NTFS | Enter to continue
Selected 'Write' and Rebuild
Write partition table confirm: Y
[but it didn't give me the option of fixing the bytes per sector problem]
REBOOT
Select PhysicalDrive2
Intel
Analyze
Still says Warning: number of bytes per sector mismatches 512 (NTFS) != 4096 (HD)
Quick Search
Enter to continue
Still says I need to format the drive before I use it.
Doesn't look like there was any change.
paulkinzelman
#7 Post by paulkinzelman »
Is there something I can do manually to change the bytes per sector mismatch?
It doesn't look like the steps you suggested seemed to do that unless I followed them incorrectly.
Any help would be appreciated.
TIA!
#8 Post by cgrenier »
Run TestDisk, go in Advanced, select the NTFS partition, choose Boot, RebuildBS, List. If you can see your files, choose Write and confirm. Quit and reboot.
paulkinzelman
#9 Post by paulkinzelman »
I tried that (to the 'List' item) and it still says" "Can't open filesystem. Filesystem seems damaged."
Is there some way I can go in there manually and fix the bytes-per-sector problem?
What's strange is that one tool out there (GetDataBack) can recover the structure of the directories but not the files themselves, and your tool photorec seems to be able to recover the files, but not the directory structure. That makes me think that there should be some way to recover both.
This is what I get when I try your sequence:
ntfs_boot_sector
NTFS at 0/4/5
Info: size boot_sector 1953519616, partition 244189952
filesystem size 1953519616 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 2 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: OK
Status: Bad
Sectors are not identical.
#10 Post by cgrenier »
Run TestDisk, select the disk, go in the Geometry menu, set the sector size to 512, go back in Advanced, choose Boot, List. Does it work this time ?
