where is log file
makdaddy
where is log file
#1 Post by makdaddy »
I understand that there should be a log file in the testdisk folder. Is it possible that this is not created even when you select create new log file?
is there a command that i can enter before lauching to create a log file?
# testdisk log ddmmyytestdisk.log
Ben
Re: where is log file
testdisk.log file is created in the current working directory when you start TestDisk and choose "Create" or if you run "testdisk /log".
makdaddy
#3 Post by makdaddy »
yes i am expecting to see that but why is it not there?
Thank you for your assistance on this issue
Im running 10.7.5 terminal app
If TestDisk failed to create it, it display a warning. As you didn't report this warning message, the log file should be here...
makdaddy
#5 Post by makdaddy »
yes I understand what you are saying. Is this a hidden file?
#6 Post by cgrenier »
No, it's not an hidden file.
pieropingi
#7 Post by pieropingi »
Windows: if you did a link to start testdisk (or photorec) in a cmd.exe window, you have to check the working dir in the link properties. In my case it was %windir%. Log file will be there.
