After using photorec how can i get original filenames
Blze
#1 Post by Blze »
After i had recovery files from my mistake (ฺBy photorec)that i use ext hdd "Seagate goflex 500gb" as a "Time machine back up" of Mac book and it format the external hdd. So i can get many of the recup_dir.xx folder and i arrange by photorec sorter.
If it possible to get the original filenames? Please help me Thank you
Re: After using photorec how can i get original filenames
Unfortunately TestDisk can't be used in your case. So no miracle solution to get the original filenames, sorry.
Blze
#3 Post by Blze »
Thank you,sir :|
