I feel like my log file is telling me useful information that could help me fix the filesystem of a lost partition that I am trying to recover, but I need help analyzing what the log file is saying.
I can read the files of this partition:
HPFS - NTFS 5100 0 1 10010 254 63 78895215
but this is the partition I am trying to recover:
HPFS - NTFS 2550 0 1 5099 254 63 40965750
I would love to figure out how to understand the log files, but I don't know where to begin. Any information that would lead me in the right direction would be appreciated.
Sat May 10 10:37:10 2014
Compiler: GCC 4.7, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=82348277760
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=626112069632
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=82351471104
Disk \\.\PhysicalDrive0 - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 82 GB / 76 GiB - CHS 10011 255 63, sector size=512
Drive C: - 626 GB / 583 GiB - CHS 76120 255 63, sector size=512
Drive E: - 82 GB / 76 GiB - CHS 10011 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive1 - 82 GB / 76 GiB - CHS 10011 255 63
NTFS at 0/1/1
Info: size boot_sector 160831031, partition 160842717
1 P HPFS - NTFS 0 1 1 10011 254 63 160842717
NTFS at 0/1/1
filesystem size 160831031
mftmirr_lcn 2
HPFS - NTFS 0 1 1 10011 69 32 160831031
NTFS, blocksize=4096, 82 GB / 76 GiB
* HPFS - NTFS 0 1 1 10011 254 63 160842717
1 * HPFS - NTFS 0 1 1 10011 254 63 160842717
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 0/1/1
mftmirr_lcn 2
NTFS at 5099/254/63
filesystem size 40965750
mft_lcn 4
mftmirr_lcn 2560359
NTFS found using backup sector, blocksize=4096, 20 GB / 19 GiB
NTFS at 5100/0/1
filesystem size 78895215
mftmirr_lcn 4930950
NTFS, blocksize=4096, 40 GB / 37 GiB
NTFS at 10010/254/63
mftmirr_lcn 4930950
NTFS found using backup sector, blocksize=4096, 40 GB / 37 GiB
mftmirr_lcn 4930950
NTFS: Can't read MFT
HPFS - NTFS 10010 254 63 14921 254 62 78895215
This partition ends after the disk limits. (start=160826714, size=78895215, end=239721928, disk end=160836480)
The harddisk (82 GB / 76 GiB) seems too small! (< 122 GB / 114 GiB)
get_geometry_from_list_part_aux head=255 nbr=5
Not an exFAT boot sector.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 27-Mar-2013 15:35 .
5 dr-xr-xr-x 0 0 0 27-Mar-2013 15:35 ..
5741 dr-xr-xr-x 0 0 0 27-Mar-2013 15:35 $RECYCLE.BIN
2724 dr-xr-xr-x 0 0 0 17-Jan-2010 01:07 .TemporaryItems
4870 dr-xr-xr-x 0 0 0 28-Dec-2010 11:32 72df113822fd13b6e3ca73
733 dr-xr-xr-x 0 0 0 26-May-2011 15:13 Music
3524 dr-xr-xr-x 0 0 0 17-Jan-2010 00:57 My Pictures
349 dr-xr-xr-x 0 0 0 21-Mar-2013 20:05 RECYCLER
27 dr-xr-xr-x 0 0 0 21-Mar-2013 20:05 System Volume Information
3902 dr-xr-xr-x 0 0 0 9-Apr-2012 12:02 Xperia
2353 dr-xr-xr-x 0 0 0 4-Jan-2012 15:29 finepix
4703 dr-xr-xr-x 0 0 0 19-Dec-2009 10:02 ziprar
2725 -r-$MFT has invalid magic.
-r--r-- 0 0 4096 17-Jan-2010 01:07 ._.TemporaryItems
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
filesystem size 160831031 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 2 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: OK
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
Can't open filesystem. Can't decipher log file.
Re: Can't open filesystem. Can't decipher log file.
Using TestDisk, you can recover this lost partition. Use the arrow keys to switch the partitions to recover to P(rimary) or L(ogical). But as the filesystem is very damaged, you will have to try other data recovery utilities or use PhotoRec to recover your data from this partition.
