I did a terrible mistake yesterday. I erased all my harddisk.
I ran testdisk in order to recover my datas, but with no success.
The report said : the following partition can't be recovered
It seems that my harddisk it too small.
Here is the report of testdisk :
Sun May 11 19:29:11 2014
OS: Linux, kernel 3.13.0-24-generic (#46-Ubuntu SMP Thu Apr 10 19:11:08 UTC 2014) x86_64
Compiler: GCC 4.8
Compilation date: 2013-10-29T01:29:29
ext2fs lib: 1.42.9, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size 3907029168 sectors
/dev/sda: user_max 3907029168 sectors
/dev/sda: native_max 3907029168 sectors
/dev/sda: dco 3907029168 sectors
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST32000542AS, S/N:5XW23F3V, FW:CC34
Disk /dev/sdb - 2004 MB / 1912 MiB - CHS 1018 62 62, sector size=512 - USB Flash Disk, FW:1100
Disk /dev/sda - 2000 GB / 1863 GiB - ST32000542AS
Analyse Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
1 P Linux 0 32 33 242679 35 44 3898638336
2 E extended 242679 68 12 243201 78 13 8386562
5 L Linux Swap 242679 68 14 243201 78 13 8386560
recover_EXT2: s_block_group_nr=0/14872, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 487329792
recover_EXT2: part_size 3898638336
ext4 blocksize=4096 Large file Sparse superblock, 1996 GB / 1859 GiB
Linux Swap 242679 68 14 243201 77 60 8386544
SWAP2 version 1, pagesize=4096, 4293 MB / 4094 MiB
* Linux 0 32 33 242679 35 44 3898638336
P Linux Swap 242679 68 14 243201 78 13 8386560
SWAP2 version 1, pagesize=4096, 4293 MB / 4095 MiB
1 * Linux 0 32 33 242679 35 44 3898638336
2 P Linux Swap 242679 68 14 243201 78 13 8386560
block_group_nr 1
recover_EXT2: s_block_group_nr=1/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 1996 GB / 1859 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
recover_EXT2: s_block_group_nr=25/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_block_group_nr=0/149, s_mnt_count=42/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
recover_EXT2: s_blocks_count 4882432
recover_EXT2: part_size 39059456
Linux 1066 131 26 3497 217 48 39059456
ext4 blocksize=4096 Large file Sparse superblock Recover, 19 GB / 18 GiB
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux Swap 2431 151 25 2929 137 8 7999472
SWAP2 version 1, pagesize=4096, 4095 MB / 3905 MiB
recover_EXT2: s_block_group_nr=0/14724, s_mnt_count=244/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 482495744
recover_EXT2: part_size 3859965952
Linux 2929 137 25 243201 78 13 3859965952 [Data]
ext4 blocksize=4096 Large file Sparse superblock, 1976 GB / 1840 GiB
block_group_nr 1
recover_EXT2: s_block_group_nr=1/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 1976 GB / 1840 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: s_block_group_nr=5/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
recover_EXT2: s_block_group_nr=7/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: s_block_group_nr=9/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
recover_EXT2: s_block_group_nr=25/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: s_block_group_nr=27/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
recover_EXT2: s_block_group_nr=49/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 81
recover_EXT2: s_block_group_nr=81/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
recover_EXT2: s_block_group_nr=125/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
recover_EXT2: s_block_group_nr=243/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 343
recover_EXT2: s_block_group_nr=343/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 625
recover_EXT2: s_block_group_nr=625/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: s_block_group_nr=729/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2187
recover_EXT2: "e2fsck -b 71663616 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2187/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2187
recover_EXT2: s_block_group_nr=2187/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2401
recover_EXT2: s_block_group_nr=2401/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 3125
recover_EXT2: "e2fsck -b 102400000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=3125/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 3125
recover_EXT2: s_block_group_nr=3125/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 6561
recover_EXT2: "e2fsck -b 214990848 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=6561/14872, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 6561
recover_EXT2: s_block_group_nr=6561/14724, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_block_group_nr=0/14724, s_mnt_count=213/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 123056 241 2 363328 181 53 3859965952 [Data]
ext4 blocksize=4096 Large file Sparse superblock Recover, 1976 GB / 1840 GiB
This partition ends after the disk limits. (start=1976909824, size=3859965952, end=5836875775, disk end=3907029168)
NTFS at 243200/138/10
filesystem size 3907014656
mftmirr_lcn 2
HPFS - NTFS 0 32 33 243200 138 10 3907014656
NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
The harddisk (2000 GB / 1863 GiB) seems too small! (< 2988 GB / 2783 GiB)
Linux Swap 2431 151 25 2929 137 24 7999488
SWAP2 version 1, pagesize=4096, 4095 MB / 3906 MiB
Thanks !
