bonjour
Mon disque dur externe me fait des blagues: lorsque je le branche, linuxMint me dit "MFT is corrupt, cannot read its unmapped extent record 18".
J'ai exécuté testdisk, fait vraisemblablement une fausse manip mais qui n'est pas l'origine du problème (j'ai un message This partition ends after the disk limits.), rebuildé le boot sector et tenté de réparer la MFT mais sans succès.
Mon disque est il HS?
Merci pour vos lumières!
Christophe
Mon May 12 16:42:37 2014
OS: Linux, kernel 3.2.0-23-generic (#36-Ubuntu SMP Tue Apr 10 20:39:51 UTC 2012) x86_64
Compiler: GCC 4.4
Compilation date: 2013-07-30T14:11:17
ext2fs lib: 1.41.12, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
/dev/sda: size 390721968 sectors
/dev/sda: user_max 390721968 sectors
/dev/sda: native_max 390721968 sectors
/dev/sda: dco 390721968 sectors
Disk /dev/sda - 200 GB / 186 GiB - CHS 24321 255 63, sector size=512 - TOSHIBA MK2046GSX, S/N:Z76UT02UT, FW:LB013M
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - Maxtor OneTouch, FW:0122
Disk /dev/sdb - 750 GB / 698 GiB - Maxtor OneTouch
Analyse Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63
NTFS at 0/1/1
1 P HPFS - NTFS 0 1 1 91199 254 63 1465127937
Note : chkdsk cannot fix this, try ntfsfix
Inode is corrupt (0): Input/output error
Failed to load runlist for $MFT/$DATA.
highest_vcn = 0x3, last_vcn - 1 = 0xe8b3
NTFS at 0/1/1
filesystem size 1465127937
mftmirr_lcn 91570496
NTFS, blocksize=4096, 750 GB / 698 GiB
NTFS at 91200/254/63
filesystem size 1465144001
mft_lcn 2
mftmirr_lcn 48
HPFS - NTFS 0 1 2 91200 254 63 1465144001
NTFS found using backup sector, blocksize=4096, 750 GB / 698 GiB
mft_lcn 2
mftmirr_lcn 48
HPFS - NTFS 91200 254 63 182401 253 61 1465144001
This partition ends after the disk limits. (start=1465144064, size=1465144001, end=2930288064, disk end=1465149168)
The harddisk (750 GB / 698 GiB) seems too small! (< 1500 GB / 1397 GiB)
Not an exFAT boot sector.
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 384080, seq=1, main=0 res=1
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn 2
ntfs_find_mft: mftmirr_lcn 48
mft at 6291488, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 0
ntfs_find_mft: mftmirr_lcn 20725971
mft at 46928498, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 2058
ntfs_find_mft: mftmirr_lcn 5162
mft at 46931602, seq=1, main=0 res=1
mft at 146768042, seq=1, main=0 res=1
mft at 146771146, seq=1, main=0 res=1
Potential partition:
1 P HPFS - NTFS 2921 10 9 94121 9 8 1465127937
1 P HPFS - NTFS 9135 194 51 100335 193 50 1465127937
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
repair_MFT
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
