Noob here:
Have a failed WD 320G connected with a USB disk converter. Host PC OS is MSW7.
TestDisk reports host drive capacity as 320G, which is correct.
But, it reports the failed drive capacity as 11227T.
Opinions?
Thank,
Gordo
Testdisk: Bogus Drive Info
Re: Testdisk: Bogus Drive Info
Can you post the testdisk.log file content ?
Thanks
/dev/sda is HDD0 in the host computer. It is the same model as the failed drive.
Console displayed a result for /dev/sdb that is not in the logfile. If helpful, I will re-assemble the setup and run testdisk again.
Thanks again,
Gordo
logfile.txt:
Thu May 15 13:10:54 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=240944939008
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200BPVT-22ZEST0, S/N:2020202057202d44585731514241453036393135, FW:01.01A01
Thanks again,
Gordo
logfile.txt:
Ran testdisk again. Log file exceeded 1M before I shut it down. I won't try to post it. I will look for a different utility. Thanks anyway.
