Western Digital drive, recognized but not accesible Topic is solved
Firedawn
#1 Post by Firedawn »
So, this is the second time this HDD has stopped working (it's out of warranty unfortunately).
It's a 500 GB Caviar Blue (WD500AAKS)
I can see my files and partition with testdisk, but it's not accesible through Windows (the disk management says the partition is RAW).
A weird thing I noticed, is that my OS boot time (Windows 7) is much longer if this drive is plugged in.
So, I'm listening to suggestions. Desperate measures are welcome too, since I've backed up everything important.
This is testdisk's log:
Sat May 17 18:43:57 2014
TestDisk 7.0-WIP, Data Recovery Utility, April 2014
Compiler: GCC 4.8, MinGW 3.11
Compilation date: May 12 2014 19:44:22
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=40018599936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=39910899712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202241024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500105217024
filewin32_getfilesize(\\.\F:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000263577600
Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 40 GB / 37 GiB - CHS 4865 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 39 GB / 37 GiB - CHS 4852 255 63, sector size=512
Drive D: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive E: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
Drive G: - 2000 GB / 1862 GiB - CHS 243184 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive3 - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/1/1
 1 * HPFS - NTFS              0   1  1 60800 254 63  976768002
file_win32_pread(100,16,buffer,2080(0/33/2)) read err: read after end of file
file_win32_pread(100,1,buffer,2080(0/33/2)) read err: read after end of file
file_win32_pread(100,2,buffer,2082(0/33/4)) read err: read after end of file
NTFS at 0/1/1
filesystem size           976768002
sectors_per_cluster       8
mftmirr_lcn               16
clusters_per_mft_record   -10
NTFS at 0/1/1
Re: Western Digital drive, recognized but not accesible
Your disk contains bad sectors (read error listed in the log file), it's why the OS boot is longer when this disk is connected.
You need to clone this disk using gnu ddrescue to a new empty disk as described in
Once the copy is done, remove the original disk and try to access your data on the clone. Use TestDisk if necessary. It has been able to find your NTFS partition, so it should work.
Firedawn
#3 Post by Firedawn »
Thanks. I had backed up important stuff already with testdisk.
Is the Windows built in software good for attempting to fix bad sectors? Should I just format it? I want to keep using this disk, even if it is unreliable.
You really should not continue to use a disk with bad sectors.
If you don't care about the futur data, activate the SMART monitoring for this disk (see BIOS settings and download a software to monitore the SMART status), use "chkdsk /r" to scan the disk
