I plugged a WD 2TB "My Passport" Drive into a Linksys E3000 router so that the drive would be shared on the network. I was unable to map to the drive when I put in on the E3000 router so I disconnected from the router (according the the Linksys router) and plugged it into my PC. I am now getting a dialog box on my Windows 7 computer asking me to reformat the drive.
So I ran the Test disk software and below is the log. I have also looked thru the forum and there seems to be numerous failures that are similiar to mine the are using WD drives.
So here is my log file
Problem with a WD 2TB "My Passport Drive"
Re: Problem with a WD 2TB "My Passport Drive"
Can you copy/paster the log file ?
TotallyAwesome
Sure here is copy and paste of the log file. I assumed that when I posted to the forum and uploaded a attachment (the log file) that it would be available to you. So here is the copy and paste of the log
Sat May 17 18:22:56 2014
TestDisk 7.0-WIP, Data Recovery Utility, April 2014
Compiler: GCC 4.8, MinGW 3.11
Compilation date: May 12 2014 19:44:22
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000558944256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=483934601216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=16106127360
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=3000423661056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=2000364240896
Disk \\.\PhysicalDrive0 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 3000 GB / 2794 GiB - CHS 364797 255 63, sector size=512
Disk \\.\PhysicalDrive7 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive C: - 483 GB / 450 GiB - CHS 58835 255 63, sector size=512
Drive D: - 16 GB / 15 GiB - CHS 1958 255 63, sector size=512
Drive K: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive L: - 3000 GB / 2794 GiB - CHS 364780 255 63, sector size=512
Drive N: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Analyse Drive N: - 2000 GB / 1862 GiB - CHS 243197 255 63
Geometry from i386 MBR: head=116 sector=52
BAD_RS LBA=218129509 5918957
check_part_i386 1 type 72: no test
BAD_RS LBA=729050177 1083631
check_part_i386 2 type 74: no test
BAD_RS LBA=168653938 1838434
1 * Sys=72 13577 238 11 119521 238 60 1701990410
Bad relative sector.
2 * Sys=74 45381 70 3 79242 34 29 543974724
3 * NetWare 3.11+ 10498 56 41 10498 56 40 0
New options :
Dump : No
Align partition: No
Expert mode : No
New options :
Dump : No
Align partition: No
Expert mode : No
Did you use TestDisk 64bit?
In case, please repeat your diagnose using TestDisk 32bit?
Also, it's recommended to select your physically "Disk" instead of a drive.
Your partition table contain entries like:
Please repeat your diagnose using TestDisk 32bit and run Quick and Deeper Search.
In "Quick Search" testdisk searches for a boot sector and displays your partition.
Deeper Search searches additional for a backup of your boot sector and displays your partition also.
Copy and paste the content of your testdisk.log again.
If TestDisk finds any partition/s please mark it and press p to have a try to list your files.
They might be wrong?1 * Sys=72 13577 238 11 119521 238 60 1701990410
TotallyAwesome
Thanks for getting back to me. I used test64 because I have a 64bit Windows system. I will use test32 as you requested and post the log file. Have a nice day!
TotallyAwesome
I installed and used the 32 bit version of Test Disk, here is the log file
Thu May 22 03:31:40 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=3000558944256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=2000365289472
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKS-75A7B2, S/N:2020202057202d444d5753413559373834393333, FW:01.03B01
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - SAMSUNG HD103UJ, S/N:20202020202031535846394a5330303931363338, FW:1AA01117
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364797 255 63, sector size=512 - WD My Book 1140, S/N:WCAWZ0862796, FW:1003
Disk /dev/sdh - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512 - WD My Passport 0748, S/N:WX61A83Y1942, FW:1022
Disk /dev/sdh - 2000 GB / 1862 GiB - WD My Passport 0748
Analyse Disk /dev/sdh - 2000 GB / 1862 GiB - CHS 243197 255 63
Invalid NTFS or EXFAT boot
1 P HPFS - NTFS 0 32 33 243197 57 60 3906961408
