The Following Partitions can't be recovered.
mttspiii
#1 Post by mttspiii »
Good day. Erhm, my 1TB Buffalo external hard disk suddenly stopped working. The laptop can detect it, but when I checked it with Disk Management it was "unallocated". So I tried out testdisk.
Analyze > Quick Search > Advanced Search gave me this: Image
What should I do next? I really don't want to lose all the contents of the external disk (which is approx. 900+ GB).
Re: The Following Partitions can't be recovered.
Can you repeat your diagnose using testdisk 6.14 32bit?
In your testdisk folder you'll find a file called testdisk.log.
You can open it using a wordprocessor like wordpad and copy and paste the content of your testdisk.log.
Here is a step by step guide:
http://www.cgsecurity.org/wiki/TestDisk_Step_By_Step
mttspiii
#3 Post by mttspiii »
Thanks for the quick reply. Yep, I can re-analyze, give me just a little more time and I'd post the results here.
mttspiii
#4 Post by mttspiii »
Hi again.
This is from testdisk.log:
Tue May 20 17:28:29 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=367685271552
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=157285351424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=208377217024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=134217728
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - WDC WD7500BPVT-22HXZT3, S/N:WD-WX51A33Y6423, FW:01.01A01
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - BUFFALO HD-PCTU3, S/N:B2C1312233, FW:0001
Drive G: - 134 MB / 128 MiB - CHS 32 64 32, sector size=2048 - HUAWEI Mass Storage, FW:2.31
Disk /dev/sdb - 1000 GB / 931 GiB - BUFFALO HD-PCTU3
file_pread(5,16,buffer,32(0/0/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,32(0/0/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,40(0/0/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,48(0/0/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,95(0/1/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,34(0/0/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,34(0/0/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,51(0/0/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,98(0/1/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,63(0/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,63(0/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,71(0/1/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,79(0/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,254740480(15856/219/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,254740480(15856/219/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,254740481(15856/219/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,254740482(15856/219/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,254740496(15856/219/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,254740543(15856/220/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,254740559(15856/220/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,254740606(15856/221/44)) ReadFile Data error (cyclic redundancy check).
BAD_RS LBA=2221818019 14201473
file_pread(5,1,buffer,2221818019(138301/197/44)) lseek err Invalid argument
HPFS - NTFS 138301 197 44 404640 90 37 4278729288
This partition ends after the disk limits. (start=2221818019, size=4278729288, end=2205580010, disk end=1953525168)
BAD_RS LBA=1792164799 8092742
FAT16 <32M 111557 25 20 232438 131 24 1941959948
This partition ends after the disk limits. (start=1792164799, size=1941959948, end=3734124746, disk end=1953525168)
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 3328 GB / 3099 GiB)
Just in case you needed it, this is from quick search:
This is from the subsequent advanced search:
#5 Post by Fiona »
Can you run Deeper Search?
Deeper Search can find more partitions using the backup of the boot sector!
mttspiii
#6 Post by mttspiii »
I have already done Deeper Search. Its result is on the second picture of the post above (I mislabeled it as "advanced search" in the previous post).
It's this one:Image
This looks bad, does it?
#7 Post by Fiona »
I've no idea?
Because this display is only a message that some partitions arte not recoverable, because they end after disk limit.
Please confirm with continue to get to your results.
Need another screen from your final results.
mttspiii
#8 Post by mttspiii »
Ok, I redid the analysis. I'll try to post what I did step-by-step, to check if I missed anything.
I did Quick Search (I took the screenshot while the Quick Search was ongoing)
this is its result
I pressed Enter, and this is what happened
Not sure what to press (A, L, or Enter), I pressed Enter again, and this is what happened
I press Enter again, and after an overnight scan, this is the result
So I pressed Enter, this happened
I don't know if I should press A, L, or Enter, so I pressed Enter again because I might overwrite my ~1TB worth of data in the external hard disk. This happened.
Did I do anything wrong?
#9 Post by Fiona »
Nope, you didn't do anything wrong.
You have some read errors.
Perhaps some bad sectors?
It's displayed here:
http://i1284.photobucket.com/albums/a57 ... ce8c8b.jpg
And your logfile displays them also:
Please check the health status of your disk using crystaldiskinfo:
Please download the portable (zip) version.
The Installer version (exe) contains the adware open candy.
The portable version, you can unzip it and execute it directly.
On the upper left area you can watch the health status of your disk.
Clickin on it, provides more info.
Probably you'll need datarecovery software like PhotoRec.
Please let me know, what kind of filetypes (like jpg, mp3 etc..) you'd like to recover.
mttspiii
#10 Post by mttspiii »
Hm, that's 900+GB's worth of movies, games, disc images, and music (in that order of priority for restoration). Thankfully I have a backup for my documents; thus they are of a lesser priority. Overall, that's quite a variety of file types in the disc.
Also, the external hard disk turns out to be still under warranty. Will crystaldiskinfo or testdisk invalidate my warranty? And will the guys over at Buffalo be able to restore all my data?
