Harddrive seems to small Topic is solved
Gr3ger
#1 Post by Gr3ger »
I can start by saying the HDD worked perfectly before being carefully removed to the new computer.
Hi, I was just transfering some HDD's from one computer (Win XP) to another newly formated computer (win7)
When I started the new computer with the disk in it says "you need to format this HDD" and the filesystem had been renamed from NTFS to RAW.
I remove the HDD and put it in the old computer again (in hope to get it to work) and still dont work.
It is a WD 1Tb HDD but its shown as 33Mb in testdisk.
Thu Apr 19 20:20:23 2012
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=1000203804160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=33030144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=203927027200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=203927027200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1000203804160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=33030144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=203927027200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=203927027200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=20974431744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=182938420224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=203921109504
filewin32_getfilesize(\\.\F:) GetFileSize err Felaktig funktion.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Felaktig funktion.
filewin32_getfilesize(\\.\G:) GetFileSize err Felaktig funktion.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Felaktig funktion.
filewin32_getfilesize(\\.\H:) GetFileSize err Felaktig funktion.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Felaktig funktion.
filewin32_getfilesize(\\.\I:) GetFileSize err Felaktig funktion.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Felaktig funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=1000202241024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=33030144
file_pread(4,1,buffer,1953523151(1938018/15/63)) lseek err Invalid argument
file_pread(5,1,buffer,65519(64/15/63)) lseek err Invalid argument
file_pread(6,1,buffer,398299544(24792/254/63)) lseek err Invalid argument
file_pread(7,1,buffer,398299544(24792/254/63)) lseek err Invalid argument
Disk /dev/sda - 1000 GB / 931 GiB - CHS 1938018 16 63, sector size=512 - WDC WD10EACS-00D6B1, FW:01.01A01
Disk /dev/sdb - 33 MB / 31 MiB - CHS 64 16 63, sector size=512 - WDC WD10EACS-00D6B1, FW:01.01A01
Disk /dev/sdc - 203 GB / 189 GiB - CHS 24792 255 63, sector size=512 - Maxtor 6 B200P0
Disk /dev/sdd - 203 GB / 189 GiB - CHS 24792 255 63, sector size=512 - Maxtor 6 B200P0
Disk /dev/sdb - 33 MB / 31 MiB - WDC WD10EACS-00D6B1
Analyse Disk /dev/sdb - 33 MB / 31 MiB - CHS 64 16 63
NTFS at 0/1/1
heads/cylinder 255 (NTFS) != 16 (HD)
NTFS: Can't read MFT
Warning: Incorrect number of heads/cylinder 255 (NTFS) != 16 (HD)
 1 P HPFS - NTFS              0   1  1 1938015  14 63 1953520002
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sdb - 33 MB / 31 MiB - CHS 65 16 63
search_vista_part: 1
NTFS at 0/1/1
filesystem size           1953520002
sectors_per_cluster       8
mftmirr_lcn               122095000
clusters_per_mft_record   -10
     NTFS, 1000 GB / 931 GiB
This partition ends after the disk limits. (start=63, size=1953520002, end=1953520064, disk end=65520)
file_pread(5,2,buffer,64544(64/0/33)) lseek err Invalid argument
file_pread(5,1,buffer,64544(64/0/33)) lseek err Invalid argument
file_pread(5,2,buffer,64607(64/1/33)) lseek err Invalid argument
file_pread(5,1,buffer,64607(64/1/33)) lseek err Invalid argument
file_pread(5,2,buffer,65536(65/0/17)) lseek err Invalid argument
file_pread(5,1,buffer,65536(65/0/17)) lseek err Invalid argument
file_pread(5,2,buffer,65552(65/0/33)) lseek err Invalid argument
file_pread(5,1,buffer,65552(65/0/33)) lseek err Invalid argument
file_pread(5,2,buffer,65615(65/1/33)) lseek err Invalid argument
file_pread(5,1,buffer,65615(65/1/33)) lseek err Invalid argument
file_pread(5,8,buffer,64520(64/0/9)) lseek err Invalid argument
file_pread(5,1,buffer,64520(64/0/9)) lseek err Invalid argument
file_pread(5,3,buffer,64528(64/0/17)) lseek err Invalid argument
file_pread(5,3,buffer,64575(64/1/1)) lseek err Invalid argument
file_pread(5,8,buffer,64591(64/1/17)) lseek err Invalid argument
file_pread(5,11,buffer,64638(64/2/1)) lseek err Invalid argument
file_pread(5,2,buffer,66560(66/0/33)) lseek err Invalid argument
Hint: update Windows to support LBA48 (minimum: W2K SP4 or XP SP1)The harddisk (33 MB / 31 MiB) seems too small! (< 1000 GB / 931 GiB)
NTFS at 0/1/1
file_pread(5,4096,buffer,6291519(6241/9/25)) lseek err Invalid argument
file_pread(5,1,buffer,6291519(6241/9/25)) lseek err Invalid argument
file_pread(5,7,buffer,64513(64/0/2)) lseek err Invalid argument
file_pread(5,1,buffer,64513(64/0/2)) lseek err Invalid argument
And after this I cant do anymore but exit the program.
remy
Re: Harddrive seems to small
#2 Post by remy »
What size is detected in the bios ?
Gr3ger
#3 Post by Gr3ger »
It detected 1Tb (correct size) in BIOS, however I managed to fix the problem.
Appearently the GIGABYTE motherboard has somekind of setting (havent read much about it) where it for some reason saves the BIOS settings to one of the HDD's. and then make the other rest disappear.
I got myself a program where I could restore it to the factory size, and then restarted the computer. Now its working and everything is still there :)
#4 Post by Fiona »
It's like this case;
http://forum.cgsecurity.org/phpBB3/mism ... n-t32.html
Did you use another utility te set capacity back?
Please let me know.
Then, could you set your topic as solved?
remy
#5 Post by remy »
For Fiona, before topic is solved and closed : For linux users, there's probably a possibility to deal with HPA with a cli tool called "hdparm".
Gr3ger
#6 Post by Gr3ger »
Fiona wrote:It's like this case;
Please let me know.
http://hddguru.com/software/2007.07.20- ... tore-Tool/
It reseted the harddrive size to the "original" size, were asked to shut down the computer (not restart) I did so and also unplugged the power cord to be sure. Then started it up again, and the HDD were there with all the files still in it :)
Yes you can mark this thread as solved :)
#7 Post by Fiona »
Thanks for feedback! :)
I'll set the topic as solved.
