Windows 8 partition corrupted, please help?
ericgj
#1 Post by ericgj »
It's the primary HD on my friend's laptop and we are really hoping there is some way of recovering her data, or at least determining if it's possible. The physical disk is fine. But PhotoRec only found a few of her files. And I'm getting "The following partitions can't be recovered" errors.
TestDisk log (v 6.14 run under Parted Magic / UBCD), is below.
Thanks!
Eric
Wed May 21 20:52:55 2014
OS: Linux, kernel 3.10.4-pmagic (#2 Tue Jul 30 11:06:11 CDT 2013) i686
Compiler: GCC 4.8
Compilation date: 2013-07-30T16:08:31
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.5, ewf lib: none
/dev/sda: size       976773168 sectors
/dev/sda: user_max   976773168 sectors
/dev/sdb: size       62533296 sectors
/dev/sdb: user_max   62533296 sectors
/dev/sdb: native_max 62533296 sectors
Warning: can't get size for Disk /dev/md - 0 B - 1 sectors (RO), sector size=512
Warning: can't get size for Disk /dev/md126 - 0 B - CHS 1 2 4, sector size=512
Warning: can't get size for Disk /dev/md127 - 0 B - CHS 1 2 4, sector size=512
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500LT012-9WS142, S/N:S0V4ATA1, FW:0001SDM1
Disk /dev/sdb - 32 GB / 29 GiB - CHS 3892 255 63, sector size=512 - LITEONIT LMT-32L3M, S/N:TW04NG44550852BF7309, FW:LWDA
Disk /dev/sde - 2048 MB / 1953 MiB - CHS 992 64 63, sector size=512 - SanDisk U3 Titanium, FW:3.21
Disk /dev/sr1 - 6291 KB / 6144 KiB - 3072 sectors (RO), sector size=2048 - SanDisk U3 Titanium, FW:3.21
Disk /dev/sda - 500 GB / 465 GiB - ST500LT012-9WS142
Partition table type: EFI GPT
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976768646 (expected 976773167)
hdr_lba_start=34
hdr_lba_end=976768613
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 3 P MS Reserved              1107968    1370111     262144 [Microsoft reserved partition]
 1 P EFI System                  2048    1026047    1024000 [EFI system partition]
 2 P Unknown                  1026048    1107967      81920 [Basic data partition]
 4 P Unknown                  1370112    2394111    1024000 [Basic data partition]
 5 P MS Data                  2394112  948008959  945614848 [Basic data partition] [OS]
 6 P Unknown                948008960  976766598   28757639 [Microsoft recovery partition]
FAT32 at 0/32/33
FAT1 : 6206-7198
FAT2 : 7199-8191
Data : 8192-1023999
sectors : 1024000
cluster_size : 8
no_of_cluster : 126976 (2 - 126977)
fat_length 993 calculated 993
FAT32 at 0/32/33
     MS Data                     2048    1026047    1024000 [ESP]
     FAT32, blocksize=4096, 524 MB / 500 MiB
FAT32 at 63/221/31
FAT1 : 7038-7614
FAT2 : 7615-8191
Data : 8192-81919
sectors : 81920
cluster_size : 1
no_of_cluster : 73728 (2 - 73729)
fat_length 577 calculated 577
FAT32 at 63/221/31
     MS Data                  1026048    1107967      81920 [DIAGS]
     FAT32, blocksize=512, 41 MB / 40 MiB
NTFS at 85/72/52
filesystem size           1024000
sectors_per_cluster       8
mft_lcn                   42666
mftmirr_lcn               2
clusters_per_mft_record   -10
     MS Data                   346113    1370112    1024000
     NTFS found using backup sector, blocksize=4096, 524 MB / 500 MiB
NTFS at 85/72/52
mft_lcn                   42666
mftmirr_lcn               2
     MS Data                  1370112    2394111    1024000 [WINRETOOLS]
     NTFS, blocksize=4096, 524 MB / 500 MiB
NTFS at 149/6/50
filesystem size           945614848
mftmirr_lcn               2
NTFS part_offset=1225785344, part_size=484154802176, sector_size=512
NTFS at 149/6/50
mftmirr_lcn               2
     MS Data                  2394112  948008959  945614848 [OS]
     NTFS, blocksize=4096, 484 GB / 450 GiB
NTFS at 59010/211/18
filesystem size           28757639
mftmirr_lcn               2
     MS Data                919251322  948008960   28757639
     NTFS found using backup sector, blocksize=4096, 14 GB / 13 GiB
mftmirr_lcn               2
     MS Data                948008960  976766598   28757639 [PBR Image]
     NTFS, blocksize=4096, 14 GB / 13 GiB
NTFS at 60800/237/45
filesystem size           974372864
mftmirr_lcn               2
     MS Data                  2394112  976766975  974372864 [OS]
     NTFS found using backup sector, blocksize=4096, 498 GB / 464 GiB
mftmirr_lcn               2
NTFS: Can't read MFT
     MS Data                976766975 1951139838  974372864
     NTFS, blocksize=4096, 498 GB / 464 GiB
This partition ends after the disk limits. (start=976766975, size=974372864, end=1951139838, disk end=976773168)
The harddisk (500 GB / 465 GiB) seems too small! (< 998 GB / 930 GiB)
     MS Data                  1026048    1107967      81920 [DIAGSntfs_mst_post_read_fixup_warn: magic: 0x0000a42b  size: 1024   usa_ofs: 46908  usa_count: 7: Invalid argument
Record 0 has no FILE magic (0xa42b)
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 15-May-2014 12:52 .
       5 dr-xr-xr-x     0      0         0 15-May-2014 12:52 ..
      40 dr-xr-xr-x     0      0         0  7-Feb-2013 00:35 BOOT
      38 dr-xr-xr-x     0      0         0  6-Feb-2013 23:29 System Volume Information
      35 dr-xr-xr-x     0      0         0  6-Feb-2013 22:23 recovery
      45 -r--r--r--     0      0     67862  7-May-2013 13:07 ADRInfos.xml
      41 -r--r--r--     0      0       159  1-May-2014 21:45 Master.log
dir_partition inode=0
FAT: cluster=2(0x2), pos=1034240
       3 -rwxr-xr-x     0      0        45 12-Oct-2013 14:30 MASTER.LOG
X      0 -rwxr-xr-x     0      0         0  1-May-2014 17:45 ST32032.1599
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:12 ST31109.31410
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:12 ST25549.15326
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:12 ST25720.2410
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:25 ST7026.18611
FAT: cluster=2(0x2), pos=10240
X      0 -rwxr-xr-x     0      0         0  1-May-2014 17:45 ST26448.1090
X    234 drwxr-xr-x     0      0      4096 13-Sep-2012 13:22 _OOT
X    235 -rwxr-xr-x     0      0   1354480 26-Jul-2012 01:12 _OOTMGFW.EFI
X    566 -rwxr-xr-x     0      0    398156 29-Aug-2012 11:05 _OOTMGR
X    664 -rwxr-xr-x     0      0   1350896 29-Aug-2012 11:05 _OOTMGR.EFI
X   5224 drwxr-xr-x     0      0      4096 29-Aug-2012 11:09 _FI
    8752 drwxr-xr-x     0      0         0 13-Sep-2012 13:22 EN-US
X   8771 -rwxr-xr-x     0      0    398156 29-Aug-2012 11:05 _TLDR
X   8869 drwxr-xr-x     0      0      4096 13-Sep-2012 14:01 _OURCES
X   1330 drwxr-xr-x     0      0      4096  6-Feb-2013 14:12 _FI.BAK
   70403 drwxr-xr-x     0      0         0  6-Feb-2013 14:22 EFI
X   4880 drwxr-xr-x     0      0      4096  6-Feb-2013 15:26 _ELL
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:11 ST1503.25879
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:11 ST13029.15206
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:12 ST25589.31309
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:12 ST6248.14255
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:12 ST9451.2305
X  11175 drwxr-xr-x     0      0      4096  6-Feb-2013 16:15 MSI93f9.tmp
X  11175 drwxr-xr-x     0      0      4096  6-Feb-2013 16:15 MSI93fe.tmp
X  11175 drwxr-xr-x     0      0      4096  6-Feb-2013 16:16 _SI9403.TMP
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:25 ST26139.18458
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:38 ST25800.32654
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 16:38 ST8571.12285
X      0 -rwxr-xr-x     0      0         0 ntfs_mst_post_read_fixup_warn: magic: 0x00000000  size: 1024   usa_ofs: 0  usa_count: 65535: Invalid argument
Record 0 has no FILE magic (0x0)
 6-Feb-2013 17:04 ST28231.9749
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:04 ST10311.17659
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:04 ST2313.24527
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:05 ST9353.7761
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:05 ST10255.30669
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:05 ST10826.4627
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:15 ST12739.16439
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:15 ST17278.27202
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:15 ST31755.2947
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:15 ST19293.10549
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:15 ST15154.19428
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:15 ST9532.2936
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:15 ST13590.12275
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:16 ST16667.32277
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:16 ST24637.15530
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:35 ST16697.26515
X      0 -rwxr-xr-x     0      0         0  6-Feb-2013 17:35 ST7101.2933
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 16:03 ST17440.31143
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 16:03 ST714.14040
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 19:40 ST20173.12447
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 19:40 ST1775.1516
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 19:45 ST1277.7347
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 19:45 ST20642.8826
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 19:45 ST3099.19185
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 21:50 ST30523.8159
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 21:51 ST27766.26019
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 21:53 ST1368.11589
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 21:53 ST3880.27917
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 21:58 ST7106.6437
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 21:58 ST1900.8377
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 21:58 ST27726.16080
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 22:23 ST3167.16601
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 22:23 ST32676.31195
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 22:38 ST28768.13195
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 22:38 ST23562.15135
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 22:38 ST13839.23504
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 23:19 ST1388.8259
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 23:19 ST26273.9840
X      0 -rwxr-xr-x     0      0         0 13-Apr-2013 23:19 ST22322.19944
X      0 -rwxr-xr-x     0      0         0 21-Apr-2013 09:27 ST26521.23959
X      0 -rwxr-xr-x     0      0         0 21-Apr-2013 09:27 ST26922.10834
X      0 -rwxr-xr-x     0      0         0 21-Apr-2013 09:32 ST25946.30592
       0 -rwxr-xr-x     0      0         0 21-Apr-2013 09:32 ST1564.32277
X      0 -rwxr-xr-x     0      0         0 21-Apr-2013 09:32 ST13610.6243
X      0 -rwxr-xr-x     0      0         0 28-Apr-2013 16:16 ST650.29989
X      0 -rwxr-xr-x     0      0         0 28-Apr-2013 16:16 ST24826.12938
      35 dr-xr-xr-x     0      0         0  7-Feb-2013 01:05 DELL
      40 dr-xr-xr-x     0      0         0  7-Feb-2013 01:35 Preload
      50 dr-xr-xr-x     0      0         0 14-Apr-2013 01:02 System Volume Information
FAT32 at 0/32/33
FAT1 : 6206-7198
FAT2 : 7199-8191
Data : 8192-1023999
sectors : 1024000
cluster_size : 8
FAT32 at 0/32/33
FAT32 at 0/32/39
FAT1 : 6206-7198
FAT2 : 7199-8191
Data : 8192-1023999
sectors : 1024000
cluster_size : 8
FAT differs, FAT sectors=976-992/993
FAT32 at 0/32/39
     MS Data                     2054    1026053    1024000 [NO NAME]
FAT32 at 63/221/31
FAT1 : 7038-7614
FAT2 : 7615-8191
Data : 8192-81919
sectors : 81920
cluster_size : 1
FAT32 at 63/221/31
FAT32 at 63/221/37
FAT1 : 7038-7614
FAT2 : 7615-8191
Data : 8192-81919
sectors : 81920
cluster_size : 1
FAT differs, FAT sectors=560-576/577
FAT32 at 63/221/37
     MS Data                  1026054    1107973      81920 [NO NAME]
NTFS at 85/72/52
mft_lcn                   42666
mftmirr_lcn               2
NTFS at 85/72/52
mft_lcn                   42666
mftmirr_lcn               2
NTFS at 88/133/22
filesystem size           6174
sectors_per_cluster       1
mft_lcn                   2058
mftmirr_lcn               5162
clusters_per_mft_record   2
clusters_per_index_record 8
     MS Data                  1415947    1422120       6174
NTFS at 88/133/22
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                  1422120    1428293       6174 [Boot]
     MS Data                  2253101    2253100          0
     exFAT, 0 B
Partition not added.
NTFS at 149/6/49
mft_lcn                   42666
mftmirr_lcn               2
NTFS at 149/6/49
mft_lcn                   42666
mftmirr_lcn               2
     MS Data                  2394111    3418110    1024000
NTFS at 149/6/50
mftmirr_lcn               2
NTFS at 149/6/50
mftmirr_lcn               2
FAT32 at 183/220/8
FAT1 : 32-9478
FAT2 : 9479-18925
start_rootdir : 18926 root cluster : 2
Data : 18926-9691853
sectors : 9691857
cluster_size : 8
no_of_cluster : 1209116 (2 - 1209117)
fat_length 9447 calculated 9447
FAT differs, FAT sectors=0-16/9447
FAT32 at 183/220/8
     MS Data                  2953762   12645618    9691857 [NO NAME]
     FAT32, blocksize=4096, 4962 MB / 4732 MiB
LVM magic value at 250/116/34
LVM magic value at 845/3/59
     Unknown                 19872133 28823037628334054 28823037608461921
     VMFS 3356246215, 14757395 TB / 13421772 TiB
NTFS at 1295/74/52
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 20802715   20808888       6174
NTFS at 1295/74/52
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 20808888   20815061       6174 [Boot]
NTFS at 1295/173/7
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 20808907   20815080       6174
NTFS at 1295/173/7
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 20815080   20821253       6174 [Boot]
NTFS at 1296/16/25
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 20815099   20821272       6174
NTFS at 1296/16/25
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 20821272   20827445       6174 [Boot]
FAT12 at 1296/114/27
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
     MS Data                 20827448   20830327       2880 [EFISECTOR]
FAT12 at 1296/160/9
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 1296/160/9
     MS Data                 20830328   20833207       2880 [EFISECTOR]
LVM magic value at 1408/221/20
LVM magic value at 1902/196/53
LVM magic value at 1957/43/29
FAT12 at 1965/22/50
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 1965/22/50
     MS Data                 31569160   31572039       2880 [EFISECTOR]
LVM magic value at 2005/44/46
NTFS at 2017/11/3
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 32397627   32403800       6174
NTFS at 2017/11/3
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 32403800   32409973       6174 [Boot]
NTFS at 2039/7/41
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 32750843   32757016       6174
NTFS at 2039/7/41
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 32757016   32763189       6174 [Boot]
LVM magic value at 3245/202/53
FAT12 at 3303/225/43
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     MS Data                 53076912   53079791       2880 [EFISECTOR]
FAT12 at 3304/19/28
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 3304/19/28
     MS Data                 53079984   53082863       2880 [EFISECTOR]
LVM magic value at 3737/67/35
LVM magic value at 3737/67/37
LVM magic value at 3737/67/38
LVM magic value at 3737/67/59
LVM magic value at 3937/15/13
LVM magic value at 4122/130/4
LVM magic value at 7453/80/56
LVM magic value at 7753/248/11
     Unknown                130511989 13852748060010741 13852747929498752
     VMFS 821092560, 7092606 TB / 6450688 TiB
LVM magic value at 28910/155/41
NTFS at 29583/242/4
mftmirr_lcn               2
NTFS part_offset=243336265728, part_size=484154802176, sector_size=512
NTFS at 29583/242/4
mftmirr_lcn               2
     MS Data                475266144 1420880991  945614848
This partition ends after the disk limits. (start=475266144, size=945614848, end=1420880991, disk end=976773168)
NTFS at 29647/103/25
mftmirr_lcn               2
NTFS part_offset=243858210816, part_size=484154802176, sector_size=512
mftmirr_lcn               2
     MS Data                476285568 1421900415  945614848
This partition ends after the disk limits. (start=476285568, size=945614848, end=1421900415, disk end=976773168)
FAT12 at 29668/123/40
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT differs, FAT sectors=0-9/9
     MS Data                476624208  476627087       2880 [EFISECTOR]
FAT12 at 29671/42/52
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     MS Data                476667312  476670191       2880 [EFISECTOR]
NTFS at 29759/253/31
mftmirr_lcn               2
NTFS part_offset=244784283648, part_size=484154802176, sector_size=512
mftmirr_lcn               2
     MS Data                478094304 1423709151  945614848
This partition ends after the disk limits. (start=478094304, size=945614848, end=1423709151, disk end=976773168)
FAT12 at 29941/27/55
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     MS Data                481003920  481006799       2880 [EFISECTOR]
NTFS at 29996/88/37
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                481885147  481891320       6174
NTFS at 29996/88/37
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                481891320  481897493       6174
FAT12 at 29999/186/52
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     MS Data                481945704  481948583       2880 [EFISECTOR]
NTFS at 30078/208/51
mftmirr_lcn               2
NTFS part_offset=247406706688, part_size=484154802176, sector_size=512
mftmirr_lcn               2
     MS Data                483216224 1428831071  945614848
This partition ends after the disk limits. (start=483216224, size=945614848, end=1428831071, disk end=976773168)
NTFS at 30162/163/42
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                484556667  484562840       6174
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                484562840  484569013       6174
NTFS at 30198/235/54
mftmirr_lcn               2
NTFS part_offset=248394612736, part_size=484154802176, sector_size=512
mftmirr_lcn               2
     MS Data                485145728 1430760575  945614848
This partition ends after the disk limits. (start=485145728, size=945614848, end=1430760575, disk end=976773168)
LVM magic value at 30222/74/35
NTFS at 30290/130/17
mftmirr_lcn               2
NTFS part_offset=249147932672, part_size=484154802176, sector_size=512
mftmirr_lcn               2
     MS Data                486617056 1432231903  945614848
This partition ends after the disk limits. (start=486617056, size=945614848, end=1432231903, disk end=976773168)
NTFS at 58946/244/50
filesystem size           944588800
mftmirr_lcn               2
     MS Data                  2394112  946982911  944588800 [OS]
     NTFS found using backup sector, blocksize=4096, 483 GB / 450 GiB
mftmirr_lcn               2
     MS Data                946982911 1891571710  944588800
     NTFS, blocksize=4096, 483 GB / 450 GiB
This partition ends after the disk limits. (start=946982911, size=944588800, end=1891571710, disk end=976773168)
NTFS at 59010/211/17
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 484 GB / 450 GiB
mftmirr_lcn               2
     MS Data                948008959 1893623806  945614848
This partition ends after the disk limits. (start=948008959, size=945614848, end=1893623806, disk end=976773168)
mftmirr_lcn               2
mftmirr_lcn               2
     Unknown                965598754 17264270961110268 17264269995511514
     VMFS 3223142400, 8839306 TB / 8039302 TiB
NTFS at 60800/231/46
mftmirr_lcn               2
mftmirr_lcn               2
     MS Data                976766598 1005524236   28757639
This partition ends after the disk limits. (start=976766598, size=28757639, end=1005524236, disk end=976773168)
mftmirr_lcn               2
mftmirr_lcn               2
NTFS at 149/6/49
mft_lcn                   42666
mftmirr_lcn               2
NTFS at 149/6/49
mft_lcn                   42666
mftmirr_lcn               2
NTFS at 1295/74/52
mft_lcn                   2058
mftmirr_lcn               5162
NTFS at 1295/173/7
mft_lcn                   2058
mftmirr_lcn               5162
     FAT12, blocksize=512, 1474 KB
ericgj
Re: Windows 8 partition corrupted, please help?
#2 Post by ericgj »
Any suggestions on this?
Thanks,
Eric
#3 Post by Fiona »
Looks like your partition table is a kind of messed up?
Some partitions overlapping.
Especially some entries like unknown.
TestDisk displays after Quick and Deeper Search 2 partitions which at least displaying a Label like OS.
Both have a different length.
Did you try, to list your data from both partitions, because I didn't find any info in your log file?
