Hi Christophe
I'd like to get the following drive working properly:
Drive D: - 500 GB / 465 GiB - CHS 60788 255 63, sector size=512
It was the boot disk in my laptop, until Windows froze 10 hours ago, and then wouldn't reboot.
TestDisk says the boot sectors are identical.
When I chose "Repair MFT", it asked me whether I'd like to fix the MFT mirror? I said No.
I then chose list files, and got message "No file found, filesystem may be damaged".
(When I tried earlier to run chkdsk on it from within Windows, chkdsk just hung)
Please see log below. It says "NTFS filesystem need to be repaired" - how do I do that?
NTFS listing using MFT looks good (except for the "Failed to open inode: Input/output error" in the middle!)
I'd be very grateful for any advice/suggestions as to what to do next, please. thanks .. Jason
Thu May 29 20:11:29 2014
Compiler: GCC 4.7, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=127928721408
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=500000907264
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=104857600
Disk \\.\PhysicalDrive0 - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 127 GB / 119 GiB - CHS 15553 255 63, sector size=512
Drive E: - 104 MB / 100 MiB - CHS 12 255 63, sector size=512
NTFS at 0/32/33
NTFS at 12/223/20
1 * HPFS - NTFS 0 32 33 12 223 19 204800 [System Reserved]
2 P HPFS - NTFS 12 223 20 60801 48 31 976564272
ntfs_boot_sector
NTFS at 12/223/20
NTFS at 12/223/20
filesystem size 976564272
mftmirr_lcn 16
Status: OK
Status: OK
Sectors are identical.
pread: Input/output error
Failed to calculate number of free clusters: Input/output error.
repair_MFT
NTFS at 12/223/20
file_win32_pread(92,256,buffer,10214336(635/207/21)) read err: read after end of file
file_win32_pread(92,1,buffer,10214586(635/211/19)) read err: read after end of file
file_win32_pread(92,16,buffer,12321536(766/249/60)) read err: read after end of file
file_win32_pread(92,16,buffer,338904(21/24/28)) read err: read after end of file
file_win32_pread(92,1,buffer,338911(21/24/35)) read err: read after end of file
file_win32_pread(92,7,buffer,338912(21/24/36)) read err: read after end of file
NTFS listing using MFT:
5 dr-xr-xr-x 0 0 0 22-May-2014 06:55 .
5 dr-xr-xr-x 0 0 0 22-May-2014 06:55 ..
57 dr-xr-xr-x 0 0 0 1-Feb-2012 13:30 $Recycle.Bin
60 dr-xr-xr-x 0 0 0 7-Feb-2014 09:31 Program Files
247 dr-xr-xr-x 0 0 0 14-May-2014 15:49 Program Files (x86)
238049 dr-xr-xr-x 0 0 0 23-Apr-2014 15:25 tmp
168214 dr-xr-xr-x 0 0 0 24-May-2012 15:35 tmpssh-WTHsCM9272
249563 dr-xr-xr-x 0 0 0 24-May-2012 15:35 tmpssh-WTHsCM9272agent.9272
421704 dr-xr-xr-x 0 0 0 30-Sep-2012 11:27 tmpsFailed to open inode: Input/output error. <-----------------------------
sh-ZWuupU4828
142002 dr-xr-xr-x 0 0 0 30-Sep-2012 11:27 tmpssh-ZWuupU4828agent.4828
496792 dr-xr-xr-x 0 0 0 20-Feb-2013 16:59 webapp
183986 -r--r--r-- 0 0 5686 19-Feb-2008 22:48 vstx.bmp
ntfs_dir: ntfs_inode_open failed
Don't fix MFT mirror.
ntfs_boot_sector
NTFS at 12/223/20
NTFS at 12/223/20
mftmirr_lcn 16
Status: OK
Status: OK
Error reading $Mft record(s): Input/output error.
No file found, filesystem may be damaged Topic is solved
Re: No file found, filesystem may be damaged Topic is solved
Just to say that I have recovered my disk.
I ran Windows chkdsk on it again, and left it overnight. Even though it looked like it was doing nothing (except that the drive light was on), over night it got 40% through the disk before it gave up.
Well, that was enough for me to try opening it in Windows Explorer. After a long time, it eventually opened.
I was able to copy the files added/modified since my last backup.
Thanks for your TestDisk program!
Who is online
Users browsing this forum: No registered users and 0 guests
