I have an external Hard drive (Internal converted to external). It has gone RAW and trying to repair. This is as far as I got. Please help as I'm trying to recover my sons 11 years of life in pictures.
I start with
Create log file >
Disk \\.\PhysicalDrive0 - 500 GB / 465 GiB
Disk \\.\PhysicalDrive1 - 300 GB / 279 GiB
Drive C: - 489 GB / 455 GiB
Drive D: - 10436 MB / 9953 MiB
>Drive F: - 300 GB / 279 GiB
I then select drive F: the problem Hdd > Then I select partition table type >[Intel ] Intel/PC partition > Then Analyze
Drive F: - 300 GB / 279 GiB - CHS 36482 255 63
1 * Sys=72 13577 238 11 119521 238 60 1701990410
Bad relative sector.
2 * Sys=74 45381 70 3 79242 34 29 543974724
3 * NetWare 3.11+ 10498 56 41 10498 56 40 0
>[Quick Search] [ Backup ]
Try to locate partition
After that I select [ Backup ] and after a while it crashes and it gives me this.
Analyse cylinder 2/36481: 00%
Read error at 1/232/40 (lba=30720)
If close progrma and retry to analyze again it gives me this error message
RAW HDD attempting to repair
Re: RAW HDD attempting to repair
Run TestDisk, select "Disk \\.\PhysicalDrive1", Advanced, Boot, List.
Does it work ? If it's not the case, please post the testdsk.log file content.
I have tried what you advised did not work. Here is the log file. Thanks for taking the time.
Sat May 31 23:09:24 2014
TestDisk 7.0-WIP, Data Recovery Utility, May 2014
Compiler: GCC 4.8, MinGW 3.11
Compilation date: May 20 2014 10:35:50
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=300088631296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=489564405760
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=10436476928
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=300082857984
Disk \\.\PhysicalDrive0 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 300 GB / 279 GiB - CHS 36483 255 63, sector size=512
Drive C: - 489 GB / 455 GiB - CHS 59519 255 63, sector size=512
Drive D: - 10436 MB / 9953 MiB - CHS 1268 255 63, sector size=512
Drive F: - 300 GB / 279 GiB - CHS 36482 255 63, sector size=512
NTFS at 0/1/1
1 P HPFS - NTFS 0 1 1 36482 254 63 586099332
NTFS, blocksize=4096, 300 GB / 279 GiB
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
filesystem size 586099332
mftmirr_lcn 36631208
Status: OK
Status: OK
Sectors are identical.
Failed to open inode $MFTMirr: Input/output error.
Failed to load $MFTMirr: Input/output error.
If I select List
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
If I select List
AlainDelon
Hi
Have you tried in >[None] Non partitioned media
[Analyse]
Don't anything ie no action taken or more damage done. Just look at the results and post the results.
When experimenting don't do anything further looked at the results first.Then decide later.
[Analyse]
AlainDelon
Hi
[Analyse]
I forgot to ask: isthe backup is on the on the same damaged HDD or another undamage HDD?
[Analyse]
AlainDelon
Pls read this thread all of it http://forum.cgsecurity.org/phpBB3/unab ... 75-20.html
