Help Recovering after format
kar90
#1 Post by kar90 »
Good morning, i am trying to recover my olde partitions and docuemnts using testdisk without success. I used to have two partitions C (50 gb) and E(250 gb), i reinstalled my windows vista and after the reinstallation windows created a partition C of 20 gb . The partition E with all mu docuements is lost. I created a new partition in the empty unrecognized space ( new partition E of 300 gb) and i formatted it to be recognized by windows. After that i used testdisk to try to find the documents that used to be in E but nothing appeared. I have tried too eliminating that partition again and using testdisk to find the old partitions but i didnt get my lost partition.
Thanks
Re: Help Recovering after format
If you'd like to achieve best results, you should run testdisk deeper search (not only quick search).
If partitions are found, you can mark them and press p to have a try to list your files.
You can open your testdisk.log (within your testdisk folder) using a wordprocessor like wordpad and copy and paste the content into your next post.
kar90
#3 Post by kar90 »
This is the log after deeper scan
Wed Jun 4 08:11:47 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
Compilation date: 2014-06-01T10:13:39
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=32395755520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=32395755520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=316934193152
filewin32_getfilesize(\\.\D:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=419429351424
filewin32_getfilesize(\\.\F:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=20971520000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=32391561216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=299098963968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Y:)=513802240
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - WDC WD7500BPVX-75JC3T0, S/N:WX61A2316479, FW:01.01A01
Disk /dev/sdb - 32 GB / 30 GiB - CHS 3938 255 63, sector size=512 - Generic- xD/SD/M.S., FW:1.00
Disk /dev/sdc - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - TOSHIBA MK3252GSX, S/N:152D20337A0C
Disk /dev/sdc - 320 GB / 298 GiB - TOSHIBA MK3252GSX
Analyse Disk /dev/sdc - 320 GB / 298 GiB - CHS 38913 255 63
NTFS at 0/32/33
NTFS at 2549/196/16
1 * HPFS - NTFS 0 32 33 2549 196 15 40960000
2 P HPFS - NTFS 2549 196 16 38913 37 36 584177664
NTFS at 0/32/33
filesystem size 40960000
mftmirr_lcn 2559999
NTFS, blocksize=4096, 20 GB / 19 GiB
NTFS at 2549/196/16
filesystem size 584177664
mftmirr_lcn 36511103
NTFS, blocksize=4096, 299 GB / 278 GiB
file_pread(6,2,buffer,625143808(38913/102/38)) lseek err Invalid argument
file_pread(6,1,buffer,625143808(38913/102/38)) lseek err Invalid argument
file_pread(6,8,buffer,625142528(38913/82/18)) lseek err Invalid argument
file_pread(6,1,buffer,625142528(38913/82/18)) lseek err Invalid argument
file_pread(6,8,buffer,625142656(38913/84/20)) lseek err Invalid argument
file_pread(6,8,buffer,625142784(38913/86/22)) lseek err Invalid argument
file_pread(6,8,buffer,625142912(38913/88/24)) lseek err Invalid argument
file_pread(6,8,buffer,625143040(38913/90/26)) lseek err Invalid argument
file_pread(6,8,buffer,625143168(38913/92/28)) lseek err Invalid argument
file_pread(6,8,buffer,625143296(38913/94/30)) lseek err Invalid argument
file_pread(6,8,buffer,625143424(38913/96/32)) lseek err Invalid argument
file_pread(6,8,buffer,625143552(38913/98/34)) lseek err Invalid argument
file_pread(6,8,buffer,625143680(38913/100/36)) lseek err Invalid argument
file_pread(6,1,buffer,625143807(38913/102/37)) lseek err Invalid argument
file_pread(6,14,buffer,625143809(38913/102/39)) lseek err Invalid argument
file_pread(6,3,buffer,625143823(38913/102/53)) lseek err Invalid argument
file_pread(6,3,buffer,625143870(38913/103/37)) lseek err Invalid argument
file_pread(6,8,buffer,625143886(38913/103/53)) lseek err Invalid argument
file_pread(6,11,buffer,625143933(38913/104/37)) lseek err Invalid argument
file_pread(6,2,buffer,625145855(38913/135/6)) lseek err Invalid argument
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 10-Jul-2013 14:43 .
5 dr-xr-xr-x 0 0 0 10-Jul-2013 14:43 ..
35 dr-xr-xr-x 0 0 0 26-May-2014 08:16 $RECYCLE.BIN
41 dr-xr-xr-x 0 0 0 29-Jan-2011 02:13 System Volume Information
39 dr-xr-xr-x 0 0 0 1-Feb-2011 21:01 myfolder
dir_partition inode=35
Directory /$RECYCLE.BIN
35 dr-xr-xr-x 0 0 0 26-May-2014 08:16 .
45 dr-xr-xr-x 0 0 0 4-Jun-2013 09:39 S-1-5-21-1438214324-4001780036-2444811649-1000
40 dr-xr-xr-x 0 0 0 2-Feb-2011 17:30 S-1-5-21-1505416850-2722177934-1438711192-1001
47 dr-xr-xr-x 0 0 0 26-May-2014 08:16 S-1-5-21-253082250-529623626-2700073115-1001
36 dr-xr-xr-x 0 0 0 24-Jan-2011 01:24 S-1-5-21-2918889525-4052927893-2995645375-1000
38 dr-xr-xr-x 0 0 0 7-Mar-2013 10:47 S-1-5-21-946613286-2098783162-2803149262-1000
dir_partition inode=45
Directory /$RECYCLE.BIN/S-1-5-21-1438214324-4001780036-2444811649-1000
45 dr-xr-xr-x 0 0 0 4-Jun-2013 09:39 .
35 dr-xr-xr-x 0 0 0 26-May-2014 08:16 ..
46 -r--r--r-- 0 0 129 4-Jun-2013 09:39 desktop.ini
dir_partition inode=40
Directory /$RECYCLE.BIN/S-1-5-21-1505416850-2722177934-1438711192-1001
40 dr-xr-xr-x 0 0 0 2-Feb-2011 17:30 .
43 -r--r--r-- 0 0 129 2-Feb-2011 17:30 desktop.ini
dir_partition inode=36
Directory /$RECYCLE.BIN/S-1-5-21-2918889525-4052927893-2995645375-1000
36 dr-xr-xr-x 0 0 0 24-Jan-2011 01:24 .
37 -r--r--r-- 0 0 129 24-Jan-2011 01:24 desktop.ini
dir_partition inode=39
Directory /myfolder
39 dr-xr-xr-x 0 0 0 1-Feb-2011 21:01 .
NTFS at 0/32/33
mftmirr_lcn 2559999
NTFS at 2549/196/15
mftmirr_lcn 2559999
NTFS found using backup sector, blocksize=4096, 20 GB / 19 GiB
NTFS at 2549/196/16
NTFS at 38913/37/36
NTFS found using backup sector, blocksize=4096, 299 GB / 278 GiB
Eunice5653
#4 Post by Eunice5653 »
For the safety of the reserved data, you’d better not overwrite or format this partition next time before you’ve rescued all important data back.
In fact, I have ever had the similar formatted partition data loss problems and tried a lot of data recovery software online, like Recuva, TestDisk, iCare Data Recovery Free and more.
All of them worked well on my computer and finally, I had restored all my wanted files and videos back successfully.
Therefore, you may take chances with other similar data recovery programs.
Next time, always make data backups all the time.
I hope my words can help you.
#5 Post by Fiona »
As already mentionned above, you shouldn't write anything to an affected disk after loss of data.
Looks like that your myfolder is empty?
In case, datarecovery software might help.
You can try PhotoRec.
PhotRec doesn't keep file names, folder and directories.
Some information;
Another useful tip, you can use PhotRec / File opt and pressing s to deselect all unneeded files and mark only your required files, where you'd like to recover.
If you'd like to recover file names and directories, you'd need/test commercial datarevovery software.
