Synology missing partition Topic is solved
kostrzu
#1 Post by kostrzu »
Hi To All
Durring migrating my disk to new synology device my data partition get deleted.
No format on hard disk was preformed.
Now i have in my system only system partitions.
Disk /dev/sda: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 311 2490240 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary
/dev/sda2 311 572 2097152 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary
So I'm looking for partition sda3. - with my data.
Can You help me with this ?
Greetings. and waiting for Your help.
remy
Re: Synology missing partition
#2 Post by remy »
Please give feedback :
sudo mdadm --examine /dev/sda1
sudo mdadm --examine /dev/sda2
kostrzu
#3 Post by kostrzu »
this is result:
DiskStation> mdadm --examine /dev/sda1
/dev/sda1:
Magic : a92b4efc
Version : 0.90.00
UUID : 72bafc43:c15354b3:3017a5a8:c86610be (local to host DiskStation )
Creation Time : Sat Jan 1 01:00:03 2000
Raid Level : raid1
Used Dev Size : 2490176 (2.37 GiB 2.55 GB)
Array Size : 2490176 (2.37 GiB 2.55 GB)
Raid Devices : 2
Total Devices : 1
Preferred Minor : 0
Update Time : Sat Apr 21 23:08:54 2012
State : clean
Active Devices : 1
Working Devices : 1
Failed Devices : 1
Spare Devices : 0
Checksum : 5dddbeff - correct
Events : 440
Number Major Minor RaidDevice State
this 0 8 1 0 active sync /dev/hda1
0 0 8 1 0 active sync /dev/hda1
1 1 0 0 1 faulty removed
DiskStation> mdadm --examine /dev/sda2
/dev/sda2:
Magic : a92b4efc
Version : 0.90.00
UUID : 4d1b0aeb:d365c075:3017a5a8:c86610be (local to host DiskStation)
Raid Level : raid1
Used Dev Size : 2097088 (2048.28 MiB 2147.42 MB)
Array Size : 2097088 (2048.28 MiB 2147.42 MB)
Raid Devices : 2
Total Devices : 2
Preferred Minor : 1
Update Time : Sat Apr 21 07:58:56 2012
State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Checksum : 4a49617d - correct
Events : 23
this 0 8 2 0 active sync /dev/sda2
0 0 8 2 0 active sync /dev/sda2
1 1 8 18 1 active sync /dev/hdb2
please help me help....
remy
#4 Post by remy »
scanning with testdisk, option : cylinder boudary-> no (or perhaps alignement-> no depending version) you should in quicksearch or deepersearch recover an md3 with another linux partition.
Don't "write", i just need to diagnoze first.
Edit : will be disconneted soon for 24 hours. Please be patient. Precipitation is not good in datarecovery.
kostrzu
#5 Post by kostrzu »
Can You please give me step by step instructions. What to do? Next. Should I remove disk from Synology and connect to PC?
Please
Greetings from Poland.
remy
#6 Post by remy »
Thought you already removed it from the NAS. I need linux command line so if you remove it from synology, connect on Linux OS.
Did you have only one disk in the first device, or was it a real raid1 ?
kostrzu
#7 Post by kostrzu »
On the first device that was only one disk. That was one bay unit.
So I need to disconnect disk from synology.
Then coonect to pc running Linux OS? ( can you recomend any)
Then i can try to give You ssh connection.?
Let me know if this steps are right.
remy
#8 Post by remy »
kostrzu wrote:On the first device that was only one disk. That was one bay unit.
Best solution is to run PC with linux and connect your disk inside your computer (quickest).
kostrzu wrote: Then coonect to pc running Linux OS? ( can you recomend any)
Ubuntu is good, and user friendly.
kostrzu wrote: Then i can try to give You ssh connection.?
I can try to repair from ssh connection but :
- I am professional in datarecovery and if I do the job, it's not free. If I help you, there in the forum, it's usefull for everyone and it's free because helping community. If you choose first option, contact me by Private Message or by mail through my website.
- I won't be connected until tonight or tomorrow.
After connecting your disk and launching gnu/linux,
1/ Verify what's the name of your disk with
sudo sfdisk -luS
2/ Download and uncompress tastdsik-6.14, copy testdisk_static in your personnal folder
3/ Launch
sudo ~/testdisk_static /dev/yourdisk
4/ Change option to "alignement :no"
5/ Select table intel and perform simple Analyse / Quicksearch / Deepersearch.
6/ Give feedback about what testdisk found on these steps
7/ Do not use "WRITE" because it's only for diagnose purpose.
kostrzu
#9 Post by kostrzu »
Hi to all
Problem solved by remmy usinng ssh connection.
This was perfect i have my data back.
This guy is perfect.!
Greetings and please close this post as solved.
Artur from Poland
