First of all, thank-you for this software. I can't say that it has saved my life yet, but I'm working on it. :)
I have a similar question to the one at http://forum.cgsecurity.org/phpBB3/phot ... t3378.html . However, I didn't want to hijack that thread, and my situation is probably not identical anyway.
SUMMARY: I think I need to manually mount the target drive before I run Photorec, but I'm not having any luck doing that. Can someone tell me the right command to mount an encrypted drive read-only?
LONGER VERSION:
I have a laptop running Ubuntu 13.10. It has two drives: /dev/sda (the boot drive) is a 120 GB SSD, and /dev/sdb (secondary drive, where I store most of my data) is a 500 GB HDD. As with the author of the above thread, the secondary drive is encrypted. I'm new to running my own Linux machine, so right now this machine is pretty much running various defaults. During the set-up process I was asked if I wanted to encrypt the secondary drive and I selected yes, and created a pass phrase. I believe this was encrypted using LUKS. Each time I log in I must enter the pass phrase to access the secondary hard drive. This is the way I want it, so everything is good from that perspective.
Being a Windows refugee I'm still evaluating and/or getting used to software that is new to me. On Windows I was using a plain-text editor (Textpad) that automatically stripped the trailing spaces in a file each time it saved. I liked this feature and found a plug-in for Gedit that did the same thing. I made the mistake of running this plug-in on a 1.1 MB file in which I am constantly adding and removing notes, and have been for years. To make a long story short, the load on the machine spiked and this plug-in was obviously not up to the job on a file this big, and I ended up killing it and Gedit.
Result: My 1.1 MB file was now only about 12 kB; 99% of my data in that file was gone, all the newest data from about 300 lines in to the end, of course.
The file was not deleted, per se, but apparently seems to have been overwritten, so I'm hoping there's still something on the drive for me to recover. (Hence my selection of the "file recovery" sub-forum instead of the "file undelete" sub-forum.) I only really need a few hundred lines from the end of the file, so even a fragment would be fine.
I very quickly unmounted the drive (/dev/sdb) to prevent further writes to it, and have been reading about file recovery ever since. Photorec looked like the best place to start. I was going to try and mount the drive read-only, but it seemed to me (from what I was seeing and reading) that maybe Photorec might do this or access the drive somehow. I found it odd that I was never asked for the pass phrase for the drive, but Photorec seemed to be doing something, so I left it for the four hours it took to tell me that there were no recoverable files.
So I decided to mount the drive and try again, but I'm getting errors. Looking at the properties for the drive shown in the file browser (which I believe is Nautilus) told me that the drive is "ext3/ext4". I found it odd that both are shown, but that's what it shows. So I tried mounting it like this:
sudo mount -t ext4 -o ro,noload /dev/sdb /romount
mount: wrong fs type, bad option, bad superblock on /dev/sdb,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
sudo mount -t ext4 -o ro,noload /dev/sdb1 /romount
mount: wrong fs type, bad option, bad superblock on /dev/sdb1,
dmesg | tail or so
Here is what looks to me like the relevant part of "dmesg":
[133424.725224] EXT3-fs (sdb): error: can't find ext3 filesystem on dev sdb.
[133424.725319] EXT4-fs (sdb): VFS: Can't find ext4 filesystem
[133424.725388] FAT-fs (sdb): Unrecognized mount option "noload" or missing value
[133598.738011] EXT4-fs (sdb): VFS: Can't find ext4 filesystem
[133736.662950] EXT4-fs (sdb): VFS: Can't find ext4 filesystem
[133903.874913] EXT4-fs (sdb1): VFS: Can't find ext4 filesystem
leftseat@selous:~/recovered20140605/photorec$ sudo fdisk -l
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, total 234441648 sectors
Disk identifier: 0x000a59df
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 226050047 113024000 83 Linux
/dev/sda2 226050048 234438655 4194304 82 Linux swap / Solaris
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Disk identifier: 0x00000000
/dev/sdb1 1 976773167 488386583+ ee GPT
Partition 1 does not start on a physical sector boundary.
Disk /dev/mapper/cryptswap1: 4294 MB, 4294967296 bytes
255 heads, 63 sectors/track, 522 cylinders, total 8388608 sectors
Disk identifier: 0xe33a2cd8
Disk /dev/mapper/cryptswap1 doesn't contain a valid partition table
leftseat@selous:~/recovered20140605/photorec$ sudo parted -l
Model: ATA INTEL SSDMCEAW12 (scsi)
Disk /dev/sda: 120GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number Start End Size Type File system Flags
1 1049kB 116GB 116GB primary ext4 boot
2 116GB 120GB 4295MB primary
Model: ATA HGST HTS725050A7 (scsi)
Disk /dev/sdb: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Number Start End Size File system Name Flags
1 1049kB 500GB 500GB primary
Model: Linux device-mapper (crypt) (dm)
Disk /dev/mapper/cryptswap1: 4295MB
Partition Table: loop
Number Start End Size File system Flags
1 0.00B 4295MB 4295MB linux-swap(v1)
Can anyone tell me what I'm doing wrong in trying to mount the hard drive read-only? Should I be using a different file system type?
Thanks very much in advance for your assistance.
Craig
