My disk is too small? Too small for what?
flyvapnet
#1 Post by flyvapnet »
I'm running TestDisk 6.14.0.0 in an effort to fix my C disk, since CHKDSK quit working several months ago. (It won't start on re-boot.) My disk is "dirty" and until it's "fixed" neither Windows nor third-party defragmenters will operate.
Lo and behold, TestDisk tells me "The harddisk <40 GB / 37 GB> seems too small! << 80 GB / 74 Gib>"! It's not going to get any bigger, so what should I do now?
Also, TestDisk informed me:
Partition / Start / End / Size in sectors
> HPPS - NTFS / 5166 239 63 / 10333 238 62 / 78124977
What I'm wanting TestDisk to do is FIX the "dirty" disk. Perhaps I failed to properly interpret the large print (which giveth) or else I didn't see the fine print (which taketh away). In the event, isn't TestDisk supposed to fix "dirty" disks? I sure wish it would, but it doesn't seem so inclined.
Please help me, if you're able, via helpful advice. Thank you very much!
AlainDelon
Re: My disk is too small? Too small for what?
#2 Post by AlainDelon »
Hi there.
I don't know much about Testdisk but I do have HDD that failed to boot. My advice is turned this HDD that failed to boot as a slave drive and connect this HDD to your PC to copy all the data via USB X.0 to SATA/IDE interface. Then reformat the HDD in order to use it. The data is totally intact in your HDD unless the HDD is totally defective/ not running at all.
#3 Post by Fiona »
A message like:
has no significance, because it's only a message that testdisk can't recover it, because your partition ends probably after disk limit.
Important are the results.
Until yet, your infos are too little to judge it
Some info about the size of your disk would be important and repeat your diagnose running testdisk / Analyse / Quick and if it's possible Deeper Search also.
You can copy and paste the content of your testdisk.log into your next post.
But it's only necessary if your disk size is recognized correctly.
If not, please let me know.
Also check the size of your disk in your disk management console.
flyvapnet
#4 Post by flyvapnet »
Thank you, AlainDelon and Fiona, for your advice! I'll get back to you on this.
flyvapnet
#5 Post by flyvapnet »
Fiona, here are some data:
Mon Jun 23 18:58:07 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
OS: Windows XP SP3
Compilation date: 2014-06-21T09:12:27
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=40007761920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=40007761920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=39999988224
Disk /dev/sda - 40 GB / 37 GiB - CHS 5168 240 63, sector size=512 - FUJITSU MHV2040AH, FW:00840096
Disk /dev/sda - 40 GB / 37 GiB - FUJITSU MHV2040AH
Analyse Disk /dev/sda - 40 GB / 37 GiB - CHS 5168 240 63
Geometry from i386 MBR: head=240 sector=63
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 5166 239 63 78124977
NTFS at 0/1/1
filesystem size 78124977
mftmirr_lcn 4882811
NTFS, blocksize=4096, 39 GB / 37 GiB
file_pread(4,2,buffer,78141440(5168/20/21)) lseek err Invalid argument
file_pread(4,1,buffer,78141440(5168/20/21)) lseek err Invalid argument
file_pread(4,1,buffer,78140160(5168/0/1)) ReadFile The drive cannot find the sector requested.
file_pread(4,14,buffer,78140161(5168/0/2)) lseek err Invalid argument
file_pread(4,3,buffer,78140175(5168/0/16)) lseek err Invalid argument
file_pread(4,3,buffer,78140222(5168/0/63)) lseek err Invalid argument
file_pread(4,8,buffer,78140238(5168/1/16)) lseek err Invalid argument
file_pread(4,11,buffer,78140285(5168/1/63)) lseek err Invalid argument
file_pread(4,2,buffer,78142207(5168/32/32)) lseek err Invalid argument
file_pread(4,1,buffer,78140178(5168/0/19)) lseek err Invalid argument
file_pread(4,1,buffer,78140225(5168/1/3)) lseek err Invalid argument
file_pread(4,1,buffer,78140246(5168/1/24)) lseek err Invalid argument
file_pread(4,1,buffer,78140296(5168/2/11)) lseek err Invalid argument
file_pread(4,1,buffer,78142209(5168/32/34)) lseek err Invalid argument
NTFS at 0/1/1
mftmirr_lcn 4882811
NTFS at 5166/239/63
mftmirr_lcn 4882811
NTFS found using backup sector, blocksize=4096, 39 GB / 37 GiB
NTFS at 5166/239/63
mftmirr_lcn 4882811
file_pread(4,1024,buffer,84419567(5583/73/9)) lseek err Invalid argument
file_pread(4,1,buffer,84419567(5583/73/9)) lseek err Invalid argument
NTFS: Can't read MFT
HPFS - NTFS 5166 239 63 10333 238 62 78124977
This partition ends after the disk limits. (start=78125039, size=78124977, end=156250015, disk end=78140160)
The harddisk (40 GB / 37 GiB) seems too small! (< 80 GB / 74 GiB)
Here are data pertaining to my computing system:
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer Microsoft Corporation
System Name MRCAT-08607D7B3
System Manufacturer IBM
System Model 1847W76
System Type X86-based PC
Processor x86 Family 6 Model 13 Stepping 8 GenuineIntel ~1862 Mhz
BIOS Version/Date IBM 76ET69WW (1.29 ), 12/6/2006
SMBIOS Version 2.33
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
User Name MRCAT-08607D7B3\Joe
Time Zone Pacific Daylight Time
Total Physical Memory 1,536.00 MB
Available Physical Memory 600.49 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 3.60 GB
Page File C:\pagefile.sys
Please let me know what I should do next. Thank you very much!
