The problem is that today i disconnected a hard drive from power without unmounting it. This isn't the first time so i didn't worried too much but after i connected the hdd again i can't access the partition. Gparted says that it's unallocated space and i can do nothing.
So i installed testdisk scanned for partitions but nothing there. I also did a deeper scan but still nothing. When it analyses the cylinder i get these results where Downloads was the mount name for the partition.
After the deeper scan finishes i get this screen
The output of the fdisk -l command for the hdd is
kostas@kostas:~$ sudo fdisk -l /dev/sdd
[sudo] password for kostas:
Disk /dev/sdd: 1000.2 GB, 1000204886016 bytes
224 heads, 19 sectors/track, 459004 cylinders, total 1953525168 sectors
Disk identifier: 0x23342335
Device Boot Start End Blocks Id System
/dev/sdd1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
kostas@kostas:~$
Mon Jun 9 16:14:23 2014
OS: Linux, kernel 3.13.0-24-generic (#47-Ubuntu SMP Fri May 2 23:30:00 UTC 2014) x86_64
Compiler: GCC 4.8
Compilation date: 2013-10-29T01:29:29
ext2fs lib: 1.42.9, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
User is not root!
Disk /dev/sda - 400 GB / 372 GiB - CHS 48641 255 63, sector size=512 - WDC WD4000AAKS-00TMA0, S/N:WD-WCAPW1513407, FW:12.01C01
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD1001FALS-00J7B0, S/N:WD-WMATV0452537, FW:05.00K05
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EADS-00P8B0, S/N:WD-WCAVU0237174, FW:01.00A01
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00ZF5A0, S/N:WD-WMC1S2520330, FW:80.00A80
Disk /dev/sde - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200JB-00KFA0, S/N:WD-WCAMR2440125, FW:08.05J08
Disk /dev/sdd - 1000 GB / 931 GiB - WDC WD10EZEX-00ZF5A0
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
Geometry from i386 MBR: head=224 sector=19
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 0 32 33 12 223 19 204800
block_group_nr 1
recover_EXT2: s_block_group_nr=1/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 244190646
recover_EXT2: part_size 1953525168
Linux 0 0 1 121601 80 63 1953525168 [Downloads]
ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 1000 GB / 931 GiB
Partition not added.
block_group_nr 3
recover_EXT2: s_block_group_nr=3/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
recover_EXT2: s_block_group_nr=25/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2187
recover_EXT2: "e2fsck -b 71663616 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2187/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
HFS magic value at 42220/8/29
part_size 34192
HFS 42220 8 29 42222 41 11 34192 [QuickTime Installer]
HFS blocksize=512, 17 MB / 16 MiB
block_group_nr 3125
recover_EXT2: "e2fsck -b 102400000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=3125/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 6561
recover_EXT2: "e2fsck -b 214990848 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=6561/7452, s_mnt_count=245/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
* HFS 42220 8 29 42222 51 5 34816 [QuickTime Installer]
HFS blocksize=512, 17 MB / 17 MiB
1 * HFS 42220 8 29 42222 51 5 34816 [QuickTime Installer]
NTFS at 12/223/19
filesystem size 204800
mft_lcn 8533
mftmirr_lcn 2
HPFS - NTFS 0 32 33 12 223 19 204800 [System Reserved]
block_group_nr 1
block_group_nr 3
block_group_nr 5
block_group_nr 7
block_group_nr 9
block_group_nr 25
block_group_nr 27
block_group_nr 49
block_group_nr 81
block_group_nr 125
block_group_nr 243
block_group_nr 343
block_group_nr 625
block_group_nr 729
block_group_nr 2187
block_group_nr 2401
part_size 34192
block_group_nr 3125
block_group_nr 6561
* HPFS - NTFS 0 32 33 12 223 19 204800 [System Reserved]
P HFS 42220 8 29 42222 51 5 34816 [QuickTime Installer]
Support for this filesystem hasn't been enable during compilation.
1 * HPFS - NTFS 0 32 33 12 223 19 204800 [System Reserved]
2 P HFS 42220 8 29 42222 51 5 34816 [QuickTime Installer]
NTFS signature is missing.
Not an exFAT boot sector.
New options :
Dump : No
Align partition: Yes
Expert mode : No
Please help me as i don't want to lose the data.
The partition is ext4 filesystem and i run Ubuntu 14.04
