Using TestDisk, I am trying to take an Image of a corrupt 400gb WD hard drive on a laptop. The resulting image on the 1tb USB hard drive is only 4gb. It reports back: “No space left for the file image” Why?
The following steps were followed:
Loaded DOS on to virtual drive on defaulting laptop using Windows 7 repair disk
Plugged 1tb NTFS USB hard drive into USB port
Ran Testdisk_win.exe from laptop CD
Chose:
No log
Selected media:
400gb WD Hard drive (NTFS)
Chose partition/table type:
Intel/PC partition
Chose:
[ Advanced ] File system utilities
Chose:
2 * HPFS – NTFS 770154496 sectors (primary bootable)
Chose:
[ Image creation ] at bottom of screen
Chose:
f drive (USB 1tb drive. Has approx. 650gb free)
Chose the appropriate destination folder
Chose:
C to start creating the image
TestDisk Stopped/failed at approx. 1.4% having created an image of only 4.2gb. There is still 648gb of free space left on the destination hard drive yet the responding message says: “No space left for the file image” Why?
Any help would be appreciated.
Thank you
TestDisk only creating 1.4% of image then stops
Re: TestDisk only creating 1.4% of image then stops
What file system do you want to copy your files to.
Fat32 for example only support file size up to 4 GB.
Who is online
Users browsing this forum: No registered users and 1 guest
