I'm trying to recover my PC after it stopped booting with a "no operating system found message"
I can't find any partitions and can't recover the boot sector. It looks pretty terminal - am I reading this right. Any other ideas? It seems odd it can go this wrong after working perfectly well.
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ATA ST3500630AS
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ATA ST3500630AS
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ATA ST3500630AS
Disk /dev/mapper/isw_chjahbbhhh_Volume0 - 1500 GB / 1397 GiB - CHS 2930304000 1 1, sector size=512
Disk /dev/mapper/isw_chjahbbhhh_Volume01 - 1500 GB / 1397 GiB - CHS 2930298880 1 1, sector size=512
Disk /dev/sr1 - 564 MB / 538 MiB - CHS 275748 1 1 (RO), sector size=2048 - SONY DVD-ROM DDU1615
Disk /dev/sda - 500 GB / 465 GiB - ATA ST3500630AS
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 0 32 33 182402 203 9 2930298880
Computes LBA from CHS for Disk /dev/sda - 500 GB / 465 GiB - CHS 60802 255 63
search_vista_part: 1
ntfs_boot_sector
filesystem size 662041453937111260 1
sectors_per_cluster 7 0
mft_lcn 72680198 0
mftmirr_lcn 806760787 0
clusters_per_mft_record 4 0
clusters_per_index_record 69 0
Status: Bad
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
Disk /dev/sdb - 500 GB / 465 GiB - ATA ST3500630AS
Ask the user for vista mode
search_vista_part: 0
Store new MBR code
Disk /dev/sdc - 500 GB / 465 GiB - ATA ST3500630AS
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60802 255 63
ntfs_boot_sector
mft_lcn 72680198 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
mft at 43257018, seq=1, main=0 res=1
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn 2058
ntfs_find_mft: mftmirr_lcn 5162
mft at 43258074, seq=1, main=0 res=1
mft at 488381944, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 183143679
mft at 490820736, seq=1, main=0 res=1
mft at 499695648, seq=1, main=0 res=1
mft at 551578296, seq=1, main=0 res=1
mft at 560587426, seq=1, main=0 res=1
mft at 560692320, seq=1, main=0 res=1
mft at 580024736, seq=1, main=0 res=1
mft at 604154784, seq=1, main=0 res=1
mft at 607554688, seq=1, main=0 res=1
mft at 610615264, seq=1, main=0 res=1
mft at 614955298, seq=1, main=0 res=1
mft at 614956354, seq=1, main=0 res=1
mft at 616152450, seq=1, main=0 res=1
mft at 616153506, seq=1, main=0 res=1
mft at 616276800, seq=1, main=0 res=1
mft at 618195224, seq=1, main=0 res=1
mft at 624746968, seq=1, main=0 res=1
mft at 637093146, seq=1, main=0 res=1
mft at 641803000, seq=1, main=0 res=1
mft at 648231330, seq=1, main=0 res=1
mft at 648232386, seq=1, main=0 res=1
mft at 648355872, seq=1, main=0 res=1
mft at 651820384, seq=1, main=0 res=1
mft at 655886976, seq=1, main=0 res=1
mft at 663433504, seq=1, main=0 res=1
mft at 665856824, seq=1, main=0 res=1
mft at 668775192, seq=1, main=0 res=1
mft at 670449728, seq=1, main=0 res=1
mft at 671172352, seq=1, main=0 res=1
mft at 674709816, seq=1, main=0 res=1
mft at 674788928, seq=1, main=0 res=1
mft at 675055072, seq=1, main=0 res=1
mft at 678790202, seq=1, main=0 res=1
mft at 678791258, seq=1, main=0 res=1
ntfs_boot_sector
mft_lcn 72680198 0
Status: Bad
Status: Bad
Unable to rebulid boot sector - can't find any partitions
barneywalker
Re: Unable to rebulid boot sector - can't find any partition
The size of your current partition in your partition table is about three time as big as the available space of your disk.
Your partition has 182402 cylinder and your disk has 60802 cylinder only.
That's why rebuilding a boot sector and anything else on your partition doesn't work!
Please don't change or modify something if you're not sure.
Can you run TestDisk and "Deeper Search" to have a look if a backup of your boot sector will be found?
The backup of a boot sector should be located at the end of your NTFS-Partition.
If testdisk finds your correct partition using the backup of a boot secor, and lists your files, you can recover it.
barneywalker
Thanks Fiona. Inadvertently you solved it for me!! The partition three times the size of the disk was the clue that got me thinking. The pc has three hard disks that came configured as a RAID array. My BIOS settings got wiped somehow and went back to default values - including SATA configured as AHCI. I updated back to RAID and the box booted up fine. Should have checked it first. Thanks for the help.
