Corrupted Kingston 8GB USB Flash
AlainDelon
#1 Post by AlainDelon »
Hi Fiona and Christophe,
I read a few threads before I started such as http://forum.cgsecurity.org/phpBB3/usb- ... -t462.html,
http://forum.cgsecurity.org/phpBB3/anot ... t2865.html and http://forum.cgsecurity.org/phpBB3/usb- ... t3413.html before using PhotoRec and Testsdisk.
I face the same problem as they do. I also read this http://diskdrive.wordpress.com/category/data-recovery/
I have a corrupted Kingston 8GB USB Flash drive that contains some data. The data is still there.
I managed to salvage 90 percentiles of the files.Recovered of all the files except for 2 Rich Text File(.rtf) corrupted files which were the root cause of the Kingston USB Flash drive to fail to work . For more, pls read my thread: http://forum.cgsecurity.org/phpBB3/reco ... t3917.html
What does the result meant? Can I setup a boot sector since my file structure is OK?
I used TestDisk to read the Kingston 8GB USB Flash first with >[None] Non partitioned media
[Analyse].
I got this result >[None] Non partitioned media
[Analyse]
>Disk /dev/sdb - 7754 MB / 7395 MiB
>Disk /dev/sdc - 7754 MB/7395 MiB - CHS 942 255 63
P unknown 0 0 1 942 186 12 15144960
>[Quick Search]
Disk /dev/sdc - 7754 MB/7395 MiB - CHS 942 255 63 [KINGSTON]
>P FAT32 0 51 60 942 186 12 15141688
Structure:Ok.
Keys T:change type, P:list files,
FAT32, blocksize=4096,7752 MB/7393 MiB
I pressed P to list files not all files found, only html files are all there but not mp4.
But when I used >[Intel] Intel/PC partition
>Disk /dev/sdc - 7754 MB/7395 MiB - Kingston Datatraveler 2.0
[Proceed]
[Analyse]
Partition sector doesn't have the end mark 0xAA55
All empty
>[Deeper Search]
Keys A: add partition, L: load backup, Enter: to continue
>[Advanced] Filesystem Utils
No partition available
Pls advice.Thank you
