I wouldn't need to waste space by copying the files, like the previous script.
This script moves files, and compares the sizes.
It keeps a duplicate if its less than the previous size, and puts it into a dupes folder, or to replace the current file with a bigger copy, in hopes for a 2nd chance recovery.
#!/usr/bin/env python
Jason C. Rochon
University of Illinois at Chicago
I don't know anything about Python, dog - I'm a Perl Frog.
But this is an example of a kludge to recover some data
after a horrible Microsoft Windows NTFS chkdsk [usb]: /f/x/r
This program will move and organize your recovered files by extension.
If the destination file exists:
* if size is same:
deletes the currently recovered file (no wasted space)
* else:
moves smaller file into a duplicate sub folder (2nd chance recovery)
(corruption increased file size on previous file, or current file is compressed)
* if the duplicate file is the same as both the current and previous:
moves same size file into duplicate sub folder (exact copy, 2nd chance recovery)
Copyright (C) 2014 Jason C. Rochon
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
import os.path
import shutil
import sys
while not (len(sys.argv) == 3):
sys.exit('Needs source and destination directories: [source] [destination]\n')
source = sys.argv[1]
destination = sys.argv[2]
if not os.path.exists(source):
sys.exit('Source directory must exist: [source] '+ destination +'\n')
if not os.path.exists(destination):
sys.exit('Destination directory must exist: ' + source + ' [destination]\n')
for root, dirs, files in os.walk(source, topdown=False):
for myFile in files:
currFile = os.path.join(root,myFile)
extension = os.path.splitext(myFile)[1][1:].lower()
destPath = os.path.join(destination,extension)
destFile = os.path.join(destPath,myFile)
dupePath = os.path.join(destPath,'dupes')
dupeFile = os.path.join(dupePath,myFile)
if not os.path.exists(destPath):
os.mkdir(destPath)
if not os.path.exists(dupePath):
os.mkdir(dupePath)
if os.path.exists(destFile):
mySize = os.path.getsize(os.path.join(root,myFile))
destSize = os.path.getsize(destFile)
print '\nmySize: ' + str(mySize) + '\ndestSize: ' + str(destSize)
if (mySize > destSize):
print '\nremove dest file: ' + destFile
os.remove(destFile)
print '\nmove curr file: ' + currFile + ' to dest path: ' + destPath
shutil.move(currFile, destPath)
else:
if os.path.exists(dupeFile):
dupeSize = os.path.getsize(dupeFile)
print '\ndupeSize: ' + str(dupeSize)
if (mySize >= dupeSize):
print '\nremove dupe file: ' + dupeFile
os.remove(dupeFile)
print '\nmove curr file: ' + currFile + ' to dupe path: ' + dupePath
shutil.move(currFile, dupePath)
else:
print '\nremove curr file: ' + currFile
os.remove(currFile)
else:
else:
- Start the PhotoRec session
- Stop the PhotoRec session
- Start the script: script.py [source] [destination]
- Manage your sorted files (delete, move, et cetera)
- Start the PhotoRec session, and restore previous session
