Hi, I have the external drive from a friend, it's a WD 500 Gb, he had a problem transferring the information to the PC and now appears as empty, with RAW format in Disk Manager, and when is connected to the PC take long to access it.
When is analyzed with Testdisk (intel) don't find partitions (Partition: Read error), nor with quick search or search deeper, only find errors constantly.
I suppose now I have to do is write the MBR, but I want to assure.
Many thanks
I add a portion of the log file:
RAW disk, no partition detected
Re: RAW disk, no partition detected
Most of recent WD external disk are encrypted and need to be accessed by their own sata-usb interface. Please plug the disk by usb and try again to scan.yarboclo wrote:Hi, I have the external drive from a friend, it's a WD 500 Gb, he had a problem transferring the information to the PC and now appears as empty, with RAW format in Disk Manager, and when is connected to the PC take long to access it.
Hello, thanks for answer.
It's connected with his USB cable. It can't be connected directly because don't have a standard SATA connection.
Did you use testdisk 64bit?
You should use testdisk 32bit instead and don't choose drive bit disk.
Disk is your physically disk and not a partition (drive)
A partition doesn't have a partition table because the partition table is a part of the MBR.
Can your repeat your diagnose and open your testdisk.log using a wordprocessor like wordpad?
Text might be better readable.
You can copy and paste the content of your testdisk log direct into your next post using code or quote!
Hello, I'm using the version of 32 bits.
I select this (now is connected to my laptop):
I paste only a portion of log file, because despite I stoped the analisys after 2 or 3 seconds, is a file with a lot of pages plenty of error lines.
Best regardsMon Jul 14 18:20:35 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
Compilation date: 2014-06-21T09:12:27
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=128035676160
filewin32_getfilesize(\\.\PhysicalDrive1) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive1) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=127928369152
filewin32_getfilesize(\\.\D:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500073234432
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - SAMSUNG SSD PM810 2.5" 7mm 128GB, S/N:2020202020203053524e454e4241304332383934, FW:AXM08D1Q
Drive E: - 500 GB / 465 GiB - CHS 976705536 1 1, sector size=512 - WD Elements 10A8, S/N:WX81A53W0259, FW:1042
Drive E: - 500 GB / 465 GiB - WD Elements 10A8
Analyse Drive E: - 500 GB / 465 GiB - CHS 976705536 1 1
file_win32_pread(300,1,buffer,19(19/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,66(66/0/1)) read err: read after end of file
file_win32_pread(300,8,buffer,80(80/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,137(137/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2050(2050/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,20(20/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,67(67/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,88(88/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,138(138/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2051(2051/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,3(3/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,4(4/0/1)) read err: read after end of file
file_win32_pread(300,14,buffer,5(5/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,21(21/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,68(68/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,89(89/0/1)) read err: read after end of file
file_win32_pread(300,11,buffer,129(129/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2052(2052/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,22(22/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,69(69/0/1)) read err: read after end of file
file_win32_pread(300,8,buffer,83(83/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,140(140/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2053(2053/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,23(23/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,70(70/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,91(91/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,141(141/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2054(2054/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,6(6/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,7(7/0/1)) read err: read after end of file
file_win32_pread(300,14,buffer,8(8/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,24(24/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,71(71/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,92(92/0/1)) read err: read after end of file
file_win32_pread(300,11,buffer,132(132/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2055(2055/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,25(25/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,72(72/0/1)) read err: read after end of file
file_win32_pread(300,8,buffer,86(86/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,143(143/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2056(2056/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,26(26/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,73(73/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,94(94/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,144(144/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2057(2057/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,9(9/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,10(10/0/1)) read err: read after end of file
file_win32_pread(300,14,buffer,11(11/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,27(27/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,74(74/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,95(95/0/1)) read err: read after end of file
file_win32_pread(300,11,buffer,135(135/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2058(2058/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,28(28/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,75(75/0/1)) read err: read after end of file
file_win32_pread(300,8,buffer,89(89/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,146(146/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,2059(2059/0/1)) read err: read after end of file
file_win32_pread(300,1,buffer,29(29/0/1)) read err: read after end of file
Hello, now I get, after wait a long time, that hard disk appears on my PC with its content and format NTFS.
Long time to access the files and do not open properly in Windows.
TestDisk recognize it as "Disk", and find a partition and files. I'm copying files to another drive, and it seems that open well, but is very slow, it takes 12 hours for a video and some more.
Any advice?
Many thanks
Any advice?
Many thanks
If it takes so long, it might be possible that you have read errors, bad sectors or a faulty file system.
Read erros can cause that testdisk or your OS hang.
You should check your disk using crystal disk info.
Please use the portable version, because the windows installer (exe) contains adware open candy.
Hello, I checked it with crystal disk info:
Hello, I'm checking the disk with HDD Regenerator trying to repair bad sectors, but is very slow too, 0.48% in 13 hours...
Can I do anything else?
Many thanks
Many thanks
HDD Regenerator cannot repair physically damaged sectors, perhaps soft bads?
Have you had success to copy your files?
