My secondary hard drive (3 tb) had 3 NTFS partitions and some free gbs (200+ gbs).
Then I decided install Ubuntu 14 in the free disk space.
By mistake during the installation process I lost the 3 NTFS partitions and now I´m trying to recover them (in particular the partition called "Peliculas").
Other partition software recovery recognize these 3 partitions but is not showing all the files that these partitions contained.
The size of the partitions that this software recognize does not seems to be the same I remember.
Actually the disk has no partitions and is a GPT disk.
Here´s some pictures and the link for the log file.
https://drive.google.com/file/d/0B0SSeN ... sp=sharing
How I may proceed for correctly recover the old partition structure?
Thanks in advance!
Recovering Lost NTFS Partitions
- 1.png (18.6 KiB) Viewed 7004 times
Re: Recovering Lost NTFS Partitions
Log setting the disk as MBR:
Sun Jul 13 10:43:21 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
Compilation date: 2014-06-21T09:12:27
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249952206848
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=107374182400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=392730509312
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 840 EVO 250GB, S/N:31534244534e4641333239353836204120202020, FW:EXT0BB6Q
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - TOSHIBA DT01ACA300, S/N:20202020202020202020332044344c565358534b, FW:MX6OABB0
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - MAXTOR STM3500320AS, S/N:2020202020202020202020205139354d57443454, FW:MX1A
Disk /dev/sdb - 3000 GB / 2794 GiB - TOSHIBA DT01ACA300
recover_EXT2: s_block_group_nr=0/22292, s_mnt_count=8/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 730479616
recover_EXT2: part_size 1548869632
Linux 0 65 2 363762 71 21 5843836928
ext4 blocksize=4096 Large file Sparse superblock, 2992 GB / 2786 GiB
Linux Swap 363762 71 22 364801 65 48 16691184
SWAP2 version 1, pagesize=4096, 8545 MB / 8149 MiB
file_pread(5,2,buffer,1565566960(364801/98/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566960(364801/98/18)) lseek err Invalid argument
file_pread(5,2,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(5,2,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,2,buffer,1565567023(364801/99/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567023(364801/99/18)) lseek err Invalid argument
file_pread(5,2,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,8,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1565566080(364801/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1565566208(364801/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1565566336(364801/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,1565566464(364801/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,1565566592(364801/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,1565566720(364801/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,1565566848(364801/96/32)) lseek err Invalid argument
file_pread(5,14,buffer,1565566977(364801/98/35)) lseek err Invalid argument
file_pread(5,3,buffer,1565566991(364801/98/49)) lseek err Invalid argument
file_pread(5,3,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,8,buffer,1565567054(364801/99/49)) lseek err Invalid argument
file_pread(5,11,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(5,2,buffer,1565569023(364801/131/2)) lseek err Invalid argument
* Linux 0 65 2 363762 71 21 5843836928
P Linux Swap 363762 71 22 364801 66 1 16691200
SWAP2 version 1, pagesize=4096, 8545 MB / 8150 MiB
1 * Linux 0 65 2 363762 71 21 5843836928
2 P Linux Swap 363762 71 22 364801 66 1 16691200
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 16/113/34
filesystem size 2150400000
mftmirr_lcn 2
HPFS - NTFS 16 113 34 133872 166 54 2150400000
NTFS, blocksize=4096, 1101 GB / 1025 GiB
block_group_nr 1
recover_EXT2: s_block_group_nr=1/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 2992 GB / 2786 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
recover_EXT2: s_block_group_nr=25/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2187
recover_EXT2: "e2fsck -b 71663616 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2187/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 3125
recover_EXT2: "e2fsck -b 102400000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=3125/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
BAD_RS LBA=618754969 9049504
HPFS - NTFS 305865 16 33 443237 30 36 2206882066
This partition ends after the disk limits. (start=4913722265, size=2206882066, end=7120604330, disk end=5860533168)
block_group_nr 6561
recover_EXT2: "e2fsck -b 214990848 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=6561/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
NTFS at 130558/30/32
filesystem size 2097152000
mftmirr_lcn 2
HPFS - NTFS 16 113 34 130558 30 32 2097152000
NTFS found using backup sector, blocksize=4096, 1073 GB / 1000 GiB
NTFS at 130558/30/33
mftmirr_lcn 2
HPFS - NTFS 130558 30 33 261099 202 31 2097152000
NTFS, blocksize=4096, 1073 GB / 1000 GiB
NTFS at 130558/63/1
filesystem size 2097154048
mftmirr_lcn 2
HPFS - NTFS 16 113 34 130558 63 1 2097154048
NTFS at 133691/30/35
filesystem size 2147483648
mftmirr_lcn 2
HPFS - NTFS 16 113 34 133691 30 35 2147483648
NTFS found using backup sector, blocksize=4096, 1099 GB / 1024 GiB
NTFS at 133872/166/54
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 1101 GB / 1025 GiB
NTFS at 133872/166/55
mftmirr_lcn 2
HPFS - NTFS 133872 166 55 267728 220 12 2150400000
recover_EXT2: s_block_group_nr=0/22292, s_mnt_count=3/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 181736 114 11 545498 120 30 5843836928
ext4 blocksize=4096 Large file Sparse superblock Recover, 2992 GB / 2786 GiB
This partition ends after the disk limits. (start=2919596032, size=5843836928, end=8763432959, disk end=5860533168)
Linux 181737 1 1 545499 7 20 5843836928
This partition ends after the disk limits. (start=2919604968, size=5843836928, end=8763441895, disk end=5860533168)
Linux 181738 26 49 545500 33 5 5843836928
This partition ends after the disk limits. (start=2919622656, size=5843836928, end=8763459583, disk end=5860533168)
Linux 181745 62 14 545507 68 33 5843836928
This partition ends after the disk limits. (start=2919737344, size=5843836928, end=8763574271, disk end=5860533168)
block_group_nr 15625
recover_EXT2: "e2fsck -b 512000000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=15625/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
NTFS at 261099/202/31
mftmirr_lcn 2
NTFS at 261099/202/32
filesystem size 1048576000
mftmirr_lcn 2
HPFS - NTFS 261099 202 32 326370 160 62 1048576000
NTFS, blocksize=4096, 536 GB / 500 GiB
NTFS at 267728/220/12
mftmirr_lcn 2
NTFS at 267728/220/13
filesystem size 1050624000
mftmirr_lcn 2
HPFS - NTFS 267728 220 13 333127 46 39 1050624000
NTFS, blocksize=4096, 537 GB / 500 GiB
block_group_nr 16807
recover_EXT2: "e2fsck -b 550731776 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=16807/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 19683
recover_EXT2: "e2fsck -b 644972544 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=19683/22292, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
NTFS at 326370/160/62
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 536 GB / 500 GiB
NTFS at 332999/178/43
mftmirr_lcn 2
HPFS - NTFS 267728 220 13 332999 178 43 1048576000
NTFS at 333127/46/39
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 537 GB / 500 GiB
recover_EXT2: s_block_group_nr=0/1941, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
recover_EXT2: s_blocks_count 63602688
recover_EXT2: part_size 508821504
Linux 333128 116 45 364801 33 32 508821504
ext4 blocksize=4096 Large file Sparse superblock, 260 GB / 242 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 260 GB / 242 GiB
block_group_nr 5
recover_EXT2: s_block_group_nr=5/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
block_group_nr 7
recover_EXT2: s_block_group_nr=7/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
block_group_nr 9
recover_EXT2: s_block_group_nr=9/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
block_group_nr 25
recover_EXT2: s_block_group_nr=25/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
block_group_nr 27
recover_EXT2: s_block_group_nr=27/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
NTFS at 334019/142/11
filesystem size 1064960000
mftmirr_lcn 2
HPFS - NTFS 267728 220 13 334019 142 11 1064960000
NTFS found using backup sector, blocksize=4096, 545 GB / 507 GiB
block_group_nr 125
recover_EXT2: s_block_group_nr=125/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
block_group_nr 243
recover_EXT2: s_block_group_nr=243/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
block_group_nr 343
recover_EXT2: s_block_group_nr=343/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
block_group_nr 729
recover_EXT2: s_block_group_nr=729/1941, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8208
Linux 348812 115 40 380485 32 27 508821504
ext4 blocksize=4096 Large file Sparse superblock Recover, 260 GB / 242 GiB
This partition ends after the disk limits. (start=5603672064, size=508821504, end=6112493567, disk end=5860533168)
Linux 348814 223 18 380487 140 5 508821504
This partition ends after the disk limits. (start=5603710976, size=508821504, end=6112532479, disk end=5860533168)
Linux 348818 178 33 380491 95 20 508821504
This partition ends after the disk limits. (start=5603772416, size=508821504, end=6112593919, disk end=5860533168)
Linux 348820 123 40 380493 40 27 508821504
This partition ends after the disk limits. (start=5603801088, size=508821504, end=6112622591, disk end=5860533168)
Linux 348820 253 42 380493 170 29 508821504
This partition ends after the disk limits. (start=5603809280, size=508821504, end=6112630783, disk end=5860533168)
Linux 348823 236 22 380496 153 9 508821504
This partition ends after the disk limits. (start=5603856384, size=508821504, end=6112677887, disk end=5860533168)
Linux 348825 51 27 380497 223 14 508821504
This partition ends after the disk limits. (start=5603876864, size=508821504, end=6112698367, disk end=5860533168)
Linux 348825 246 30 380498 163 17 508821504
This partition ends after the disk limits. (start=5603889152, size=508821504, end=6112710655, disk end=5860533168)
mftmirr_lcn 2
mftmirr_lcn 2
The harddisk (3000 GB / 2794 GiB) seems too small! (< 4486 GB / 4178 GiB)
Not an exFAT boot sector.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 27-Jun-2014 20:25 .
5 dr-xr-xr-x 0 0 0 27-Jun-2014 20:25 ..
NTFS Volume is dirty.
5 dr-xr-xr-x 0 0 0 29-Jun-2014 13:12 .
5 dr-xr-xr-x 0 0 0 29-Jun-2014 13:12 ..
921 dr-xr-xr-x 0 0 0 28-Jun-2014 00:04 $RECYCLE.BIN
74 dr-xr-xr-x 0 0 0 9-Jul-2014 22:00 Downloads
4430 dr-xr-xr-x 0 0 0 29-Jun-2014 13:12 Microsoft SQL Server 2014
35 dr-xr-xr-x 0 0 0 28-Jun-2014 11:58 Revisar
919 dr-xr-xr-x 0 0 0 28-Jun-2014 00:04 System Volume Information
38 dr-xr-xr-x 0 0 0 27-Jun-2014 21:56 UltraISOPortable
5 dr-xr-xr-x 0 0 0 27-Jun-2014 20:26 .
5 dr-xr-xr-x 0 0 0 27-Jun-2014 20:26 ..
5 dr-xr-xr-x 0 0 0 28-Jun-2014 00:04 .
5 dr-xr-xr-x 0 0 0 28-Jun-2014 00:04 ..
37 dr-xr-xr-x 0 0 0 28-Jun-2014 00:04 $RECYCLE.BIN
35 dr-xr-xr-x 0 0 0 28-Jun-2014 00:04 System Volume Information
FIrst of all, please be sure to use testdisk from another disk than the one where you lost partitions.
It seems you formated the whole disk while installation. Did you wrote many datas on it ? Did you proceed the installation until it's end ? Formatting a device as ext filesystem wrote some superblocks on different places on the disk and may corrupt other previous filesystems.
When running testdisk / deepersearch, are you able to see your partition ? If yes, select it and press "P" to list files. Is it good ?
I´m running testdisk from my primary drive (SSD)remy wrote:FIrst of all, please be sure to use testdisk from another disk than the one where you lost partitions.
Yes, Ubuntu 14 was installed.remy wrote: It seems you formated the whole disk while installation. Did you wrote many datas on it ? Did you proceed the installation until it's end ? Formatting a device as ext filesystem wrote some superblocks on different places on the disk and may corrupt other previous filesystems.
In this picture I selected "Intel Partitions" and then run "Quick Search":
remy wrote: When running testdisk / deepersearch, are you able to see your partition ? If yes, select it and press "P" to list files. Is it good ?
Mon Jul 14 21:42:38 2014
NTFS at 16/113/34
mftmirr_lcn 2
block_group_nr 1
block_group_nr 3
block_group_nr 5
block_group_nr 7
block_group_nr 9
block_group_nr 25
block_group_nr 27
block_group_nr 49
block_group_nr 81
block_group_nr 125
block_group_nr 243
block_group_nr 343
block_group_nr 625
block_group_nr 729
block_group_nr 2187
block_group_nr 2401
block_group_nr 3125
This partition ends after the disk limits. (start=618754969, size=2206882066, end=2825637034, disk end=1565565872)
block_group_nr 6561
mftmirr_lcn 2
mftmirr_lcn 2
HPFS - NTFS 130558 30 33 261099 202 31 2097152000 [Varios]
NTFS at 130558/63/1
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
HPFS - NTFS 133872 166 55 267728 220 12 2150400000 [Software]
This partition ends after the disk limits. (start=2919596032, size=1548869632, end=173498367, disk end=1565565872)
This partition ends after the disk limits. (start=2919604968, size=1548869632, end=173507303, disk end=1565565872)
This partition ends after the disk limits. (start=2919622656, size=1548869632, end=173524991, disk end=1565565872)
This partition ends after the disk limits. (start=2919737344, size=1548869632, end=173639679, disk end=1565565872)
mftmirr_lcn 2
mftmirr_lcn 2
HPFS - NTFS 261099 202 32 326370 160 62 1048576000 [Nuevo vol]
mftmirr_lcn 2
mftmirr_lcn 2
HPFS - NTFS 267728 220 13 333127 46 39 1050624000 [Varios]
mftmirr_lcn 2
mftmirr_lcn 2
HPFS - NTFS 267728 220 13 332999 178 43 1048576000 [Varios]
mftmirr_lcn 2
block_group_nr 3
block_group_nr 5
block_group_nr 7
block_group_nr 9
block_group_nr 25
block_group_nr 27
mftmirr_lcn 2
HPFS - NTFS 267728 220 13 334019 142 11 1064960000 [Varios]
block_group_nr 125
block_group_nr 243
block_group_nr 343
block_group_nr 729
This partition ends after the disk limits. (start=1308704768, size=508821504, end=1817526271, disk end=1565565872)
This partition ends after the disk limits. (start=1308743680, size=508821504, end=1817565183, disk end=1565565872)
This partition ends after the disk limits. (start=1308805120, size=508821504, end=1817626623, disk end=1565565872)
This partition ends after the disk limits. (start=1308833792, size=508821504, end=1817655295, disk end=1565565872)
This partition ends after the disk limits. (start=1308841984, size=508821504, end=1817663487, disk end=1565565872)
This partition ends after the disk limits. (start=1308889088, size=508821504, end=1817710591, disk end=1565565872)
This partition ends after the disk limits. (start=1308909568, size=508821504, end=1817731071, disk end=1565565872)
This partition ends after the disk limits. (start=1308921856, size=508821504, end=1817743359, disk end=1565565872)
mftmirr_lcn 2
mftmirr_lcn 2
dir_partition inode=2
2 drwxr-xr-x 0 0 4096 4-Jul-2014 22:06 .
2 drwxr-xr-x 0 0 4096 4-Jul-2014 22:06 ..
11 drwx------ 0 0 16384 4-Jul-2014 21:45 lost+found
8142337 drwxr-xr-x 0 0 12288 4-Jul-2014 22:07 etc
6303745 drwxr-xr-x 0 0 4096 16-Apr-2014 22:21 media
4202497 drwxr-xr-x 0 0 4096 4-Jul-2014 22:07 bin
7617025 drwxr-xr-x 0 0 4096 4-Jul-2014 22:07 boot
3939841 drwxr-xr-x 0 0 4096 16-Apr-2014 22:26 dev
4333825 drwxr-xr-x 0 0 4096 4-Jul-2014 21:54 home
4071169 drwxr-xr-x 0 0 4096 4-Jul-2014 22:07 lib
8404993 drwxr-xr-x 0 0 4096 16-Apr-2014 22:21 lib64
7748353 drwxr-xr-x 0 0 4096 10-Apr-2014 19:12 mnt
12082177 drwxr-xr-x 0 0 4096 16-Apr-2014 22:21 opt
15496705 drwxr-xr-x 0 0 4096 10-Apr-2014 19:12 proc
14708737 drwx------ 0 0 4096 16-Apr-2014 22:28 root
10506241 drwxr-xr-x 0 0 4096 16-Apr-2014 22:27 run
7354369 drwxr-xr-x 0 0 12288 4-Jul-2014 22:07 sbin
4465153 drwxr-xr-x 0 0 4096 16-Apr-2014 22:21 srv
10243585 drwxr-xr-x 0 0 4096 12-Mar-2014 22:41 sys
1838593 drwxrwxrwt 0 0 4096 4-Jul-2014 22:07 tmp
9980929 drwxr-xr-x 0 0 4096 16-Apr-2014 22:21 usr
9192961 drwxr-xr-x 0 0 4096 16-Apr-2014 22:29 var
12 lrwxrwxrwx 0 0 30 4-Jul-2014 22:06 vmlinuz
13 lrwxrwxrwx 0 0 33 4-Jul-2014 22:06 initrd.img
262657 drwxrwxr-x 0 0 4096 4-Jul-2014 21:49 cdrom
¡Thanks for your help!
I Keep waiting your advices.
Here´s the partitions found by other software (I selected only scan NTFS partitions):
We can see the partition I´m looking for (Peliculas), but the problem is the missing files.
The partition "Peliculas" starts at the sector 264192 but ends in diferents sector.
I don´t know why but Testdisk does not found this partition (you can see the logs previously posted).
I hope this picture helps in some way.
