I hope you can help me with my hard disk. Here the story goes:
Suddenly, I've started to have some issues with my laptop. Mainly It gets stuck and frozen with little work, things like that.
So I looked some software I use to check hard disk health's status and it resulted in something like a bad sector pending to move to the spare area. Something like this:
After this I ran chkdsk in all partitions to correct or discard possible bad sectors, or to recover the information. I still had issues so I decided to ran the sfc from windows to restore possible corrupted vital files for the system. It worked for a while and it restored some files. Finally I reboot the computer and I verified that I've some problems yet. Less than before, but still some.
So finally I decided to use testdisk to see if I had any trouble with partition tables, but what I found out was, this:
So, the main question is.. Should I throw this hard disk to the garbage?
Any solution, if not for repairing those cylinders, at least to solve the problem, in such a way I can make useful the well-working area of the hard disk safely.
I'm thinking about format the drive and reinstall windows, but I think this won't inconsiderate those problematic cylinders, sectors and tracks, avoiding them and using the rest of the hard disk. Aslo I'm considering a low level format, but not sure about how safe this is for the hd.
Thanks in advance for any comment, and sorry for my possible faults while writting. English isn't my lenguage.
