2x WD 1tb Caviar Black in Raid 0 turned RAW Topic is solved
Dynamistic
#1 Post by Dynamistic »
I downloaded an update for my raid controller and then it asked me to restart my computer, after I come back my drive has turned RAW, I have been desperately trying to find a way to convert it back to the way it was without losing any data or spending money, can someone please help me fast?
Re: 2x WD 1tb Caviar Black in Raid 0 turned RAW
Do you have a functionally array?
Is your RAID degraded?
Did you recreate your array, exactly like before, without repartition and formatting it?
Dynamistic
#3 Post by Dynamistic »
Fiona wrote:Do you have a functionally array?
Ok i will be honest I do not understand what u mean by functionally arry or degraded array.
I haven't recreated it yet either.
Dynamistic
#4 Post by Dynamistic »
I fixed the problem with a system restore, Im shocked that something this simple fixed that, wow.
#5 Post by Fiona »
Nice to see that you were able to solve your problem
It was depend on, did you create a RAID0 using the BIOS of your RAID-controller or the controller-software under windows.
I'll set your topic as solved!
Dynamistic
#6 Post by Dynamistic »
yeah i used the bios of the raid controller
