I have a 1 TB RAID1 array on a 3ware 9650SE-2LP adapter with 2-WD 1 TB Black drives, single NTFS partion. It is a data only array, not used to boot. Running Windows 7 SP1. The drive began giving corrupted file errors, and CHKDSK would repair them on boot. Then it became inacccessible/unreadable.
The 3ware software manager 3DM2 then re-initialized the array (apparently automatically, I did not give any command to do this--it took almost 24 hours), but the files can't be accessed--CHKDSK now gives the message "Corrupted MFT--Windows will try to repair--Repair failed, CHKDSK aborting." Windows Explorer says disk is corrupted and unreadable. But 3DM2 says the array and component drives are OK. I swapped the controller for a spare I had and got the same results, so I've ruled out a bad card.
I tried running Testdisk on the array from DOS and it will not see the array (lack of RAID driver).
At this point I need to recover the data if possible to another drive and then deal with any physical disk or controller problems. I connected one of the 1TB drives to the MB controller (it still gives corrupted messages) and ran Testdisk from Windows on it. It sees the 931GB primary partition, but on List files I got the message "Can't open file system. File system seems damaged."
I'm wondering if the re-initialization the controller did may have compounded the problem (or overwritten the backup MFT?) Usually Raid controllers rebuild corrupted mirrors, but it seems this time it re-formatted it.
Should I try repairing the NTFS boot sector, the MFT or both? The page on repairing NTFS boot/MFT refers to the Advanced menu, not sure how to locate that. Screenshots and step by step instructions would help. Thanks!
Log file info:
Tue Aug 5 22:12:08 2014
TestDisk 6.14-WIP, Data Recovery Utility, April 2013
Christophe GRENIER
<grenier@cgsecurity.org>
Compilation date: 2013-
04-28T11:42:38
disk_get_size_win32
IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\
\.\PhysicalDrive1)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=73400320000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=10421796864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)
=999986036736
disk_get_size_win32
IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=0
Warning: can't get size for \\.\M:
filewin32_getfilesize(\\.\Q:)
GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\Q:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\Q:
filewin32_getfilesize(\\.\R:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\R:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\R:
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC
WD1003FBYX-01Y7B1, S/N:2020202057202d44435757413633333637323039, FW:01.01V02
Disk /dev/sdb - 120 GB / 111 GiB - CHS 55084 224 19,
sector size=512 - OCZ-VERTEX2, S/N:434f2d5a4a55595a55424d503835383252315447, FW:1.11
Disk
/dev/sda - 1000 GB / 931 GiB - WDC WD1003FBYX-01Y7B1
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS
121601 255 63
NTFS at 0/32/33
1 P HPFS - NTFS 0
32 33 121574 213 47 1953097728
Incomplete multi sector transfer detected in $MFT.
ntfs_mft_load(): Failed.
$MFT.
Incomplete multi
detected in $MFT.
Incomplete multi
Failed to startup volume:
Input/output error.
Failed to load $MFT: Input/output
error.
NTFS at 0/32/33
filesystem size 1953097728
mftmirr_lcn 2
HPFS - NTFS 0 32 33 121574 213 47 1953097728
NTFS, blocksize=4096, 999 GB / 931
GiB
file_pread(4,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,1,buffer,1953525760(121601/90/26)) lseek
file_pread(4,15,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(4,3,buffer,1953525776
(121601/90/42)) lseek err Invalid argument
file_pread(4,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread
(4,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(4,11,buffer,1953525886(121601/92/26)) lseek err Invalid
argument
file_pread(4,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
* HPFS - NTFS 0 32 33
NTFS, blocksize=4096, 999 GB / 931 GiB
Not an exFAT boot sector.
Not an exFAT
boot sector.
* HPFS - NTFS 0 32 33 121574 213 47 1953097728
Can't open
filesystem. Filesystem seems damaged.
1 * HPFS - NTFS 0 32 33 121574 213 47 1953097728
Incomplete
Input/output error.
error.
Failed to
startup volume: Input/output error.
Input/output error.
error.
Failed to load
$MFT: Input/output error.
Corrupted MFT in RAID 1 array
Who is online
Users browsing this forum: No registered users and 4 guests
