This is my first post and I would be very thankful if somebody can help me.
I have one HD with two partitions and due to power failure the system partition has malfunction.
It is a 1TB partition which was 800GB used, after the failure the OS (windows 8.1) fail to boot, after one attempt to repair from the OS with no result, I have found that the system partiton now shows only 90 gb used and most of the files are missing.
This is the result when I run TESTDRIVE on the partition affected (the other one works properly)
If I press INTEL I get this
Any idea how I should proceed?
Thanks!
