First off... this tool is saving my ass, thanks so much!
Second, thought I should let you know about an error
Using PhotoRec from the WIP produces an error after an undetermined amount of time, crashes back to CLI with the following:
PhotoRec syntax error: ,inter
[/share/USBDisk1/recovery] # ../testdisk-7.0-WIP/photorec_static /version
PhotoRec 7.0-WIP, Data Recovery Utility, August 2014
Version: 7.0-WIP
Compiler: GCC 4.4
Compilation date: 2014-08-20T21:45:05
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, ewf lib: 20120504, libjpeg: libjpeg-turbo-1.2.0
OS: Linux, kernel 3.4.6 (#1 SMP Thu Jun 12 02:38:33 CST 2014) x86_64
PhotoRec - 7.0 WIP - Error - Linux x86_64
Re: PhotoRec - 7.0 WIP - Error - Linux x86_64
I encountered the same after photorec had scanned my 20 TB XFS for about 200 hours. It found lots of files!
Where does this come from and what does it mean?
Thanks!
I called: /tmp/testdisk-7.0-WIP/photorec_static /d /mnt3/ /mnt/dumpdata1
OpenSuSE 13.2 kernel 3.16.7-7-desktop
Thanks!
First of All ...
testdisk / photorec is a great tool, thanks ...
I'm getting the same error after recovering a lot of files (130GB)
same disk to recover, photorec started on ubuntu 16.04 (32 & 64 Bit)
don't know what this means and how to workaround
This message occurs (after session restart has been used) with old version of Photorec when the recovery is finished. You can ignore this message.
