Ok forget it. The board will not allow me to upload the testdisk.log file, no matter what I change the file name or extension to read.
So here is the full contents in text format:
Your message contains 148854 characters. The maximum number of allowed characters is 60000. HAHAHAHA get me a hammer. I'm going to truncate it until it fits
Strike 1
Your message contains 75726 characters. The maximum number of allowed characters is 60000.
Wed Aug 27 10:48:10 2014
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=80000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=80000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=790478815744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=57102284288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=94379180032
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD1001FALS-00J7B0, S/N:WD-WMATV5764742, FW:05.00K05
Disk /dev/sdb - 80 GB / 74 GiB - CHS 9726 255 63, sector size=512 - ST380013AS, S/N:5MR0B9DP, FW:8.12
Disk /dev/sdb - 80 GB / 74 GiB - ST380013AS
Analyse Disk /dev/sdb - 80 GB / 74 GiB - CHS 9726 255 63
Partition: Read error
FAT16 at 0/1/1
FAT1 : 1-63
FAT2 : 64-126
start_rootdir : 127
Data : 159-64194
sectors : 64197
cluster_size : 4
no_of_cluster : 16009 (2 - 16010)
fat_length 63 calculated 63
FAT16 at 0/1/1
FAT16 >32M 0 1 1 3 254 63 64197 [DellUtility]
FAT16, blocksize=2048, 32 MB / 31 MiB
NTFS at 4/0/1
filesystem size 150095295
mft_lcn 819177
mftmirr_lcn 4194973
HPFS - NTFS 4 0 1 9346 254 63 150095295
NTFS, blocksize=4096, 76 GB / 71 GiB
FAT32 at 9347/0/1
FAT1 : 32-5956
FAT2 : 5957-11881
start_rootdir : 11882 root cluster : 2
Data : 11882-6072569
sectors : 6072570
cluster_size : 8
no_of_cluster : 757586 (2 - 757587)
fat_length 5925 calculated 5919
FAT32 at 9347/0/1
FAT32 LBA 9347 0 1 9724 254 63 6072570 [DellRestore]
FAT32, blocksize=4096, 3109 MB / 2965 MiB
file_pread(5,2,buffer,156250112(9726/30/33)) lseek err Invalid argument
file_pread(5,1,buffer,156250112(9726/30/33)) lseek err Invalid argument
file_pread(5,2,buffer,156250237(9726/32/32)) lseek err Invalid argument
file_pread(5,1,buffer,156250237(9726/32/32)) lseek err Invalid argument
file_pread(5,2,buffer,156250238(9726/32/33)) lseek err Invalid argument
file_pread(5,2,buffer,156250301(9726/33/33)) lseek err Invalid argument
file_pread(5,1,buffer,156250301(9726/33/33)) lseek err Invalid argument
file_pread(5,1,buffer,156250111(9726/30/32)) lseek err Invalid argument
file_pread(5,14,buffer,156250113(9726/30/34)) lseek err Invalid argument
file_pread(5,3,buffer,156250127(9726/30/48)) lseek err Invalid argument
file_pread(5,3,buffer,156250174(9726/31/32)) lseek err Invalid argument
file_pread(5,8,buffer,156250190(9726/31/48)) lseek err Invalid argument
file_pread(5,8,buffer,156250240(9726/32/35)) lseek err Invalid argument
file_pread(5,2,buffer,156252159(9726/63/1)) lseek err Invalid argument
* FAT16 >32M 0 1 1 3 254 63 64197 [DellUtility]
P HPFS - NTFS 4 0 1 9346 254 63 150095295
P FAT32 LBA 9347 0 1 9724 254 63 6072570 [DellRestore]
1 * FAT16 >32M 0 1 1 3 254 63 64197 [DellUtility]
2 P HPFS - NTFS 4 0 1 9346 254 63 150095295
3 P FAT32 LBA 9347 0 1 9724 254 63 6072570 [DellRestore]
write!
file_pread(5,1,buffer,0(0/0/1)) ReadFile Data error (cyclic redundancy check).
Store new MBR code
file_pwrite(5,1,buffer,0(0/0/1)) write err Read-only file system
Partition: Write error
New options :
Dump : No
Align partition: Yes
Expert mode : No
FAT16 at 0/1/1
FAT1 : 1-63
FAT2 : 64-126
start_rootdir : 127
Data : 159-64194
sectors : 64197
cluster_size : 4
FAT16 at 0/1/1
NTFS at 4/0/1
mft_lcn 819177
mftmirr_lcn 4194973
FAT32 at 9347/0/1
FAT1 : 32-5956
FAT2 : 5957-11881
sectors : 6072570
cluster_size : 8
FAT32 at 9347/0/1
FAT16 at 0/1/1
FAT1 : 1-63
FAT2 : 64-126
start_rootdir : 127
Data : 159-64194
sectors : 64197
cluster_size : 4
FAT16 at 0/1/1
NTFS at 4/0/1
mft_lcn 819177
mftmirr_lcn 4194973
file_pread(5,16,buffer,1591520(99/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1591520(99/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,2702748(168/60/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,2702748(168/60/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,5912576(368/10/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,5912576(368/10/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,5912575(368/10/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,5912575(368/10/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,5912577(368/10/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,5912578(368/10/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,5912592(368/10/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6567936(408/212/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6567936(408/212/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6567935(408/212/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6567937(408/212/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,6567938(408/212/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6567952(408/213/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6567999(408/213/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,6568015(408/214/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,6568062(408/214/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6569832(408/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6569832(408/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6569999(408/245/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6570000(408/245/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6570110(408/247/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6570110(408/247/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6570584(408/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6570584(408/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6570585(409/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,6570586(409/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6570601(409/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6570648(409/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,6570664(409/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,6570711(409/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6570651(409/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6570651(409/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,6570656(409/1/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,6570727(409/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,6570774(409/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6570654(409/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6570654(409/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6627344(412/135/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6629392(412/168/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6637694(413/45/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6641727(413/109/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6641727(413/109/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6779429(421/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6779429(421/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6779430(422/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,6779431(422/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6783039(422/57/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6783055(422/57/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6783055(422/57/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6785024(422/88/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6785024(422/88/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6785023(422/88/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6785023(422/88/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6785025(422/88/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,6785026(422/88/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6799486(423/63/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6799486(423/63/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6807678(423/193/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6807678(423/193/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6809599(423/223/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6809602(423/223/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6809612(423/224/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6809613(423/224/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6832254(425/73/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6832254(425/73/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6846464(426/44/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6846463(426/44/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6846466(426/44/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6846476(426/44/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6846477(426/44/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6846480(426/44/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6846590(426/46/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6846470(426/44/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6860816(427/16/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6862848(427/49/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6862847(427/49/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6862850(427/49/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6862862(427/49/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6862863(427/49/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6862864(427/49/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6864912(427/81/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6869055(427/147/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6869071(427/147/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6869071(427/147/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6871166(427/181/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6871166(427/181/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6873167(427/212/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6875199(427/245/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6875215(427/245/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6875215(427/245/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6891599(428/250/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6891606(428/250/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6891884(428/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6891885(429/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6891886(429/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6891892(429/0/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,6891893(429/0/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6892011(429/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6892020(429/2/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6891891(429/0/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6892027(429/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6892027(429/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6907920(429/254/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6908076(430/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6908076(430/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6908077(430/2/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6908077(430/2/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,6908092(430/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,6908139(430/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6908082(430/2/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6908082(430/2/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6927969(431/62/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6941039(432/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6941039(432/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6941165(432/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6944768(432/74/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6944034(432/62/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6944767(432/74/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6944770(432/74/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6944772(432/74/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,6944776(432/74/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6944831(432/75/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6944831(432/75/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6944774(432/74/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6944774(432/74/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6972336(434/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6972336(434/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6972337(434/2/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6972337(434/2/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6975614(434/54/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6975614(434/54/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6985791(434/215/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6991872(435/57/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6991871(435/57/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6991874(435/57/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6991884(435/57/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6991885(435/57/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,6991888(435/57/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,8568832(533/98/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,8568831(533/98/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,8568834(533/98/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,8568844(533/98/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,8568845(533/98/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,8568848(533/98/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,9527630(593/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,9601024(597/162/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,9601024(597/162/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,9601023(597/162/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,9601025(597/162/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,9601026(597/162/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,9601040(597/162/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,10711056(666/186/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,10807375(672/185/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,10807422(672/186/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,10807423(672/186/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,11198264(697/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,11198327(697/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,11198327(697/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,11198390(697/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,12154880(756/154/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,12154880(756/154/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,12154879(756/154/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,12154881(756/154/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,12154882(756/154/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,12154896(756/154/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,12154943(756/155/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,12656640(787/214/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,12656640(787/214/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,12656639(787/214/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,12656641(787/214/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,12656642(787/214/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,12656656(787/214/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,12656703(787/215/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,12656719(787/215/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,14766143(919/38/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,14766159(919/38/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,14766159(919/38/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,14960766(931/67/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,15697920(977/38/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,15697920(977/38/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,15696464(977/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,15697919(977/38/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,15697919(977/38/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,15697921(977/38/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,15697922(977/38/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,16516931(1028/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,16516931(1028/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,16530884(1028/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,16530885(1029/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,16530886(1029/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,16530892(1029/0/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,16530893(1029/0/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,16530901(1029/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,16530948(1029/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,16530964(1029/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,16531011(1029/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,16530951(1029/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,16530951(1029/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,16530956(1029/1/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,16530954(1029/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,16530954(1029/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,16857214(1049/79/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,16857214(1049/79/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,20434806(1272/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,20434806(1272/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,20434807(1272/2/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,20434807(1272/2/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,22210560(1382/138/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,22210559(1382/138/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,22210562(1382/138/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,22210564(1382/138/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,22210568(1382/138/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,22210566(1382/138/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,22210566(1382/138/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,23494782(1462/123/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,23494782(1462/123/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,25143836(1565/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,25143836(1565/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,25143422(1565/26/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,25143422(1565/26/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,25309184(1575/108/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,25309184(1575/108/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,25309183(1575/108/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,25309185(1575/108/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,25309186(1575/108/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,25309200(1575/108/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,25579646(1592/66/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,25579646(1592/66/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,26120937(1625/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,26120937(1625/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,26121000(1625/244/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,26517520(1650/163/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,29270142(1821/250/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,29270142(1821/250/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,30953598(1926/196/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33624124(2093/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33624171(2093/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33626093(2093/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33624127(2093/1/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33624143(2093/1/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,33624143(2093/1/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,33624190(2093/2/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33624187(2093/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,33624188(2093/2/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33626156(2093/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,33626156(2093/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33626127(2093/33/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33626128(2093/33/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,33626175(2093/33/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,36146392(2250/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,36149248(2250/47/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,36149247(2250/47/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,36149250(2250/47/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,36149260(2250/47/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,36149261(2250/47/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,36149264(2250/47/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,36149311(2250/48/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,36149327(2250/48/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,36149374(2250/49/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,36765712(2288/142/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,36769808(2288/207/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,38580350(2401/131/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,38580356(2401/131/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,44736512(2784/183/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,44736511(2784/183/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,44736514(2784/183/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,44736524(2784/183/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,44736525(2784/183/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,63467646(3950/172/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67183829(4181/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67183830(4182/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67183831(4182/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67183836(4182/0/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,67183838(4182/0/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,67183846(4182/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,67183893(4182/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67183896(4182/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67183897(4182/1/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,67183901(4182/1/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67184019(4182/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67184019(4182/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67183899(4182/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67183899(4182/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67274831(4187/169/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67274878(4187/170/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67274878(4187/170/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67313435(4190/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67313435(4190/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67505193(4202/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67505193(4202/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,67505209(4202/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,67505256(4202/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67505194(4202/1/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67505194(4202/1/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,67505201(4202/1/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,67505272(4202/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,67505199(4202/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,67505199(4202/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,70991872(4419/10/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,70991871(4419/10/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,70991874(4419/10/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,70991879(4419/10/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,70991880(4419/10/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,70991888(4419/10/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,70991935(4419/11/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,70991951(4419/11/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,70991998(4419/12/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71457119(4447/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71457120(4448/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71457121(4448/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,71457124(4448/0/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71469119(4448/190/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,71469119(4448/190/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71469182(4448/191/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,71469188(4448/191/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71698094(4462/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71698095(4463/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71698096(4463/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,71698108(4463/0/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,71698109(4463/0/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,71698111(4463/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71708672(4463/167/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,71708672(4463/167/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,71708671(4463/167/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71708674(4463/167/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,71708675(4463/167/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,71708680(4463/168/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,71708688(4463/168/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,71708678(4463/167/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,72446031(4509/142/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,72446036(4509/142/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,77262848(4809/99/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,77262848(4809/99/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,77262847(4809/99/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,77262849(4809/99/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,77262850(4809/99/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,86446787(5381/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,86446787(5381/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,86446850(5381/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,106942590(6656/221/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,106942590(6656/221/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140224512(8728/145/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140224512(8728/145/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140224511(8728/145/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140224513(8728/145/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,140224514(8728/145/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,140224528(8728/146/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,140224575(8728/146/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,140224591(8728/147/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,140224638(8728/147/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,140226560(8728/178/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140226559(8728/178/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,140226562(8728/178/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140226623(8728/179/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140226623(8728/179/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,140226639(8728/179/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,140226686(8728/180/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140228607(8728/210/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140228610(8728/210/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140228619(8728/211/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,4,buffer,140228620(8728/211/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,140228624(8728/211/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140230656(8728/243/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140230632(8728/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140230655(8728/243/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140230658(8728/243/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140230668(8728/243/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140230719(8728/244/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140230719(8728/244/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140230782(8728/245/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140230790(8728/245/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,140232704(8729/20/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140230695(8728/244/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140230696(8728/244/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140231384(8728/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140231384(8728/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140231385(8729/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,140231386(8729/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,140231401(8729/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,140231448(8729/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,140231464(8729/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,140231511(8729/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,140233433(8729/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,140231451(8729/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,140231527(8729/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,140231574(8729/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,140233496(8729/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,140232344(8729/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,140232407(8729/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140232703(8729/20/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140232703(8729/20/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140232704(8729/20/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140232705(8729/20/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,140232706(8729/20/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,140232720(8729/21/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,140232767(8729/21/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,140232783(8729/22/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,140232830(8729/22/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140235213(8729/60/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140235213(8729/60/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,140235276(8729/61/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,140235339(8729/62/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140433534(8741/148/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140433540(8741/148/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140665219(8756/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,140665220(8756/1/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,140665221(8756/1/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142237696(8853/226/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142237696(8853/226/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142237695(8853/226/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142237697(8853/226/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,142237698(8853/226/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,142237712(8853/226/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,142237759(8853/227/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,142237775(8853/227/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,142237822(8853/228/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,142239744(8854/3/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,142238757(8853/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,142238820(8853/244/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142239509(8853/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142239509(8853/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142239510(8854/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,142239511(8854/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,142239526(8854/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,142239573(8854/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,142239589(8854/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,142239636(8854/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142239576(8854/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142239576(8854/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,142239581(8854/1/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,142239652(8854/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,142239699(8854/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,142241621(8854/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142239579(8854/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142239743(8854/3/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142239744(8854/3/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142239745(8854/3/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,142239746(8854/3/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,142239760(8854/3/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,142239807(8854/4/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,142239823(8854/4/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,142239870(8854/5/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,142241792(8854/36/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142240595(8854/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142240595(8854/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142241791(8854/36/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,142241794(8854/36/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,142241808(8854/36/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,142241855(8854/37/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,142241871(8854/37/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,142241918(8854/38/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142243338(8854/60/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142243339(8854/60/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142243839(8854/68/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142243842(8854/68/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142243845(8854/68/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142243856(8854/68/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142243903(8854/69/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142243919(8854/69/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142243846(8854/68/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142245951(8854/102/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142245952(8854/102/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,142245967(8854/102/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,142247936(8854/133/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142247936(8854/133/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,142247935(8854/133/47)) ReadFile Data error (cyclic redundancy check).
...[truncated]...
0 [DellRestore]
Seagate partition won't write part 4? testdisk log here
Re: Seagate partition won't write part 4? testdisk log here
Doesn't look like a software fix is available for this, which is sad because the drive was working just fine and just died.
I was only able to recover about 1GB of usable data out of 75GB+ on the disk. I'll be tossing this into the box of Seagate problem drives and warning myself repeatedly to never, EVER purchase a Seagate drive again, nor purchase an OEM system that contains one.
If anyone has any useful info to add, please do, but I have given up hope to recover more data from this drive.
BTW the MODERATORS might want to just merge this post with the other 3 or 4 on this topic, since it took over a week to verify my account instead of the usual 60 seconds from other message boards of this type.
Who is online
Users browsing this forum: No registered users and 4 guests
