Hi. I'm in the UK and I have a Humax HDR Foxsat satellite recorder.
I accidentally wiped my recordings by resetting the box and I'm desperate to save them.
The box is linux based and the files that contain the video are .ts files. Each has associated sidecar files which are not crucial.
Do you think i could use phoorec for this and if so, how?
tia
recover recordings from a humax sat recorder
Re: recover recordings from a humax sat recorder
If you connect the disk to your computer and run PhotoRec, it should be able to recover your .ts files
