The command used was: dd if=/dev/zero of=/dev/sdX
The Drive has 750GB
The file system used on the Drive was NTFS
There was only one big so called "extended partition" on a dos partition table.
I have scanned the whole drive with testdisk but found no trace of any partition.
Not a suprise i guess.
I Wan to try to recreate the partition table my self but I struggle to find the right settings in testdisk
I'm asked to give the right Partition type, but I don't know how it is called in testdisk.
These are the Partition Types listed in testdisk:
List of partition type
01 FAT12 50 OnTrack DM RO a9 NetBSD
02 XENIX root 51 OnTrack DM RW-NOVEL ab Darwin boot
03 XENIX /usr 52 CP/M-Microport V/386 af HFS
04 FAT16 <32M 53 OnTrack DM WO ??? b7 BSDI
06 FAT16 >32M 54 OnTrack DM DDO b8 BSDI swap
07 HPFS - NTFS 55 EZ-Drive bc Acronis
09 AIX data 56 GoldenBow VFeature be Solaris boot
0a OS/2 Boot Manager 61 SpeedStor bf Solaris
0b FAT32 63 Unixware, HURD, SCO c1 secured FAT12
0c FAT32 LBA 64 NetWare 286 c4 secured FAT16
0e FAT16 LBA 65 NetWare 3.11+ c6 sec. Huge-bad FAT16
10 OPUS 67 Novell c7 Syrinx Boot-bad NTFS
11 hid. FAT12 68 Novell d8 CP/M-86
12 Compaq Diagnostics 69 Novell db CP/M
14 hid. FAT16 <32M 70 DiskSecure MB de Dell Utility
16 hid. FAT16 >32M 75 PC/IX e1 SpeedStor FAT12 ext
17 hid. HPFS/NTFS 80 Minix v1.1-1.4a e3 DOS RO
18 AST swap 81 Minix / old Linux e4 SpeedStor FAT16 ext
19 Willowtech Photon 82 Linux Swap eb BeFS
1b hid. FAT32 83 Linux ee EFI GPT
1c hid. FAT32 LBA 86 NT FAT16 V/S set ef EFI (FAT-12/16/32)
1e hid. FAT16 LBA 87 HPFS FT mirror-V/S set f0 Linux/PA-RISC boot
20 Willowsoft OFS1 8e Linux LVM f1 Storage Dimensions
24 NEC MS-DOS 3.x 93 Amoeba f2 DOS secondary
27 Windows RE(store) 94 Amoeba bad block f4 SpeedStor
38 Theos a0 NoteBIOS save2disk fb VMFS
3c PMagic recovery a5 FreeBSD fd Linux RAID
40 VENIX 80286 a6 OpenBSD fe LANstep
41 PPC PReP Boot a8 Darwin UFS ff Xenix bad block
42 W2K Dynamic/SFSOn an healthy drive with an very similar setup it testdisk shows me this:
1 E extended LBA 0 1 1 60800 254 63 976768002
X extended 1 0 1 60800 254 63 976752000
5 L HPFS - NTFS 1 1 1 60800 254 63 976751937
