Lost boot on a partition
jo447
#1 Post by jo447 »
I have a macbook pro with 2 hard drives. the system drive is good but I have an issue with my data drive.
It has 2 partitions: 1 for bootcamp using windows 7 and the other one for data.
the issue was with the data partition. Disk utility couldn't repair so I used testdisk (for the first time)
I could copy with testdisk all my data on an external drive, and now I'm trying to fix the drive.
I followed the step by step instruction until the press p to list files, than I changed the partition that has the issue to Primary and wrote the settings on the drive.
When I tried to reboot windows 7 it says no bootable disk.
Here is what I have now:
Screen Shot 2014-09-22 at 4.50.59 PM.png (44.28 KiB) Viewed 2470 times
I didn't have them in double before.
Then:
Screen Shot 2014-09-22 at 4.55.08 PM.png (43.46 KiB) Viewed 2470 times
I didn't have warnings before
Screen Shot 2014-09-22 at 4.59.01 PM.png (40.26 KiB) Viewed 2470 times
I don't know what this one means
jo447
Re: Lost boot on a partition
#2 Post by jo447 »
I didn't finish my post before,
so to make the story shorter,
I think my main issue is that I can't chose between P,E,D,L,* for the partitions' status.
I can only chose P or nothing
Any idea on how to get these options?
(I got my data back, and the data partition can mount again - I used org BS so thanks Testdisk!!!! But now I will need to recover the boot on my bootcamp partition)
Thanks for your help
