recover external harddrive
DerickKuch
#1 Post by DerickKuch »
Testdisk has said The disk seems too small! Unable to recover.
Below i have included a log, is there anything i can do at this point to reocover the data?
http://pastebin.com/FtaYqKef
Mon Sep 29 08:23:46 2014
TestDisk 7.0-WIP, Data Recovery Utility, August 2014
Compilation date: 2014-09-25T08:47:05
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202240512
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500104691712
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - HDS725050KLA360, S/N:202020202020524b4e563536415a41484c33464b, FW:K2AOAB0A
Disk /dev/sdb - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - KINGSTON SH103S3120G, S/N:3035323042363237413337303130383920202020, FW:507KC4
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST910004 30AS
Disk /dev/sdc - 1000 GB / 931 GiB - ST910004 30AS
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
Geometry from i386 MBR: head=255 sector=62
Invalid NTFS or EXFAT boot
 1 P HPFS - NTFS              0   1  1 121600 254 62 1953520001
BAD_RS LBA=4152106017 952922
file_pread(6,3,buffer,4152106017(258456/164/46)) lseek err Invalid argument
file_pread(6,1,buffer,4152106017(258456/164/46)) lseek err Invalid argument
     FAT16 <32M           258456 164 46 510154  75 50 4043522768
This partition ends after the disk limits. (start=4152106017, size=4043522768, end=8195628784, disk end=1953525168)
BAD_RS LBA=3153245888 11988143
file_pread(6,3,buffer,3153245888(196280/122/3)) lseek err Invalid argument
file_pread(6,1,buffer,3153245888(196280/122/3)) lseek err Invalid argument
     FAT16 >32M           196280 122  3 323887 250 20 2050014537
This partition ends after the disk limits. (start=3153245888, size=2050014537, end=5203260424, disk end=1953525168)
file_pread(6,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(6,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(6,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(6,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(6,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(6,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(6,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 4196 GB / 3907 GiB)
Not an exFAT boot sector.
Re: recover external harddrive
I assume that your Fat16<32M-partition is wrong?
It ends after disk limit, that's why it's not recoverable.
Did you only have 1 NTFS partition using the whole space?
Did you run a full scan of Deeper Search?
Might be possible that more partitions are found using backup boot sector.
Did you run a RebuildBS?
It's as long as you don't confirm at Write only a diagnose.
If it's successful, you can use the menu List to have another try to list your data.
DerickKuch
#3 Post by DerickKuch »
This is a clients external. I'm assuming it only has one partition. The deeper scan showed the same info quickscan did. The disk seems too small. I'm not sue what do next. I have only run scans on the disk.
#4 Post by Fiona »
Can you try to run a RebuildBS?
You'll find it at TestDisk / Advanced and Boot.
TestDisk will check your file system using the MFT and its mirror and will display the result.
If it's successful, you can use the menu List to have a try to list your data.
Please let me know the result.
Until yet, you shouldn't use the menu Write nor Repair MFT.
Please copy the content of your testdisk.log into your next post.
DerickKuch
#5 Post by DerickKuch »
Okay, so first i tried to use the backup BS, and it said the disk was corrupt and unreadable.. still atleast its not saying i need to reformat now.
Im using the rebuildBS as we speak and its scanning the disk right now. I will post the log as soon as im done.
EDIT: It also knows the partition is NTFS and not Fat now... so thats also another step in the right direction.
I created a sector by sector backup and am running Photorec on it atm. It has recovered some 9000 files so far. Thats good. If anything there will be recovered data. It is a FULL 1TB hard drive so im sure Photorec is going to take a long time on that. Its been 17 hours so far.
