I need to recover some mp3 and waw files from a broken 750GB drive (large portions of bad sectors). I lost all partitions, and I can't recover them. I cannot clone the drive also, beacuse all the tools i used fail to copy at some point.
Despite this, I can use photorec, but every time I launch the recovery (with different parameters, for example) it needs to start from the beginning of the disk, and it takes 8hrs to get to the right sectors!
Is there a way to start the recovery from a specific point of the disk? As a fast and esay fix for this, I'm wondering if I can "cheat" the resuming process, forcing it to start from an arbitrary sector: I had a look at "photorec.ses", tweaking the values, and "photorec.cfg" in my home (I'm using Linux), but none of these files actually helped.
Can you help me about this?
Start recovery from a specific sector
Who is online
Users browsing this forum: No registered users and 1 guest
