Disk with no format
kkoutsou
Disk with no format
#1 Post by kkoutsou »
I have an external disk that suddenly is not bootable for any OS. I tried to access it form mac, windows and linux, with no result.
I have downloaded your software in order to recover the files inthe damaged disked but I don't know exactly how your software works.
Which are the steps in order to recover my files?
kkoutsou
Re: Disk with no format
#2 Post by kkoutsou »
Hi again.
I found the instructions on the webpage.
So problem solved
thank you
