Can't find the .mov files
gglafranco
I ran my sd card through PhotoRec and was delighted to see that in addition to many jpg files it also recovered 3 .mov files. As these are the files that I have been loosing sleep over, I was very excited. However, I can't find the files on my computer. I did find the the file folders where the jpg's are stored but there were no .mov's there. Do you have a tip as to how to locate them and should I have modified my initial recovery procedures so that this would not have happened?
Re: Can't find the .mov files
Sort the file by extension in recup_dir.1 directory, there may be .mov or .avi.
