However, I cannot select the partition table type because the program freezes.
I just select the correct hard drive (it took half an hour to testdisk to list them), and the it's been 10 hours since I selected and I'v still no update to the screen.
I believe that if I have to enter the partition table type I don't have to wait for testdisk to read the whole disk to guess, huh ? And if it actually tries to auto-guess, I hope it can remember the main features, so it doesn't to rescan fully the disk or whatever. Anyway I'm concerned, I cannot see any testdisk in "iotop -P -o".
  PID  PRIO  USER     DISK READ  DISK WRITE  SWAPIN     IO>    COMMAND
 7946 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.13 % [kworker/5:2]
  334 be/3 root        0.00 B/s  677.63 B/s  0.00 %  0.11 % [jbd2/sda5-8]
  440 be/4 root        0.00 B/s  223.01 K/s  0.00 %  0.00 % systemd-journald
  839 be/4 root        0.00 B/s   11.91 K/s  0.00 %  0.00 % rsyslogd -n
 2690 be/4 denethor    0.00 B/s   31.10 K/s  0.00 %  0.00 % firefoxThank you for any help !
