I have a hard disk, on which Windows 7 was installed. Unfortunately this disk isn't recognized anymore. The disk spins and starts but only to a black screen with a blinking underscore.
Unfortunately a colleague of mine did chkdsk on this disk. Before this workaround the disk starts at least to the Windows start screen.
Testdisk only shows 6 "D" partitions, thus all as "deleted". The first one is the system one, which is also marked as deleted.
I did "list files" at all deleted partitions.
Partitions 2-4 showing error message "can't open filesystem. Filesystem seems damaged". The last 2 partitions are showing files but not those I would need.
Please see attached screenshots.
Anyone an idea how to solve this issue and get files back?
Thank you in advance.
Best wishes,
all partitions marked "D" like deleted
habmalnefrage
- Testdisk screenshot deeper search.png (50.14 KiB) Viewed 1919 times
- testdisk panorama.jpg (197.08 KiB) Viewed 1919 times
