accidently wrote bad partition instead of healthy one Topic is solved
Ultronium
#1 Post by Ultronium »
Hi!
as most poeple here, i had this RAW partition probleme, but when i runned testdisk, which im familir with, my partition was listed twice after depper search, and i think that i wrote the wrong one with the bad filesystem since i have "filesystem seems damaged " message.
does it mean i lost my healthy partition forever? :cry:
please help me im desperate ..
eclark461
Re: accidently wrote bad partition instead of healthy one
#2 Post by eclark461 »
You can navigate through the files of the drive and look for the ones that you are trying to read from and use that partition as a recovery and write the partition back to the hard drive.
However... In most cases when you have a lost partition, it makes more sense to copy all recoverable data off of the hard drive before attempting a re-write of the partition table.
Ultronium
#3 Post by Ultronium »
i can't even acces the partion through testdisk because i get "filesystem damaged " message :/
eclark461
#4 Post by eclark461 »
have you looked at the geometry section and checked that the data matches what is in the top portion of testdisk.
And be advised that TestDisk does not simply work in all cases and for everyone the same.
can you give me a pastebin of the log file that you are using as well ?
Ultronium
#5 Post by Ultronium »
thank you !seem the only one to care here...
i m really messed up and here is why:
when i run testdisk with the HDD inside my laptop, (means that i boot from windows on my defected HDD ( the partition damaged is D: not windows partition)) the numbers of heads is set to 16, but when i remove it and run testdisk from another pc it set itself to 255...
OK, i ll run testdisk through the night and ill join the log file tomorrow, with heads = 255 set in geometry settings as mentioned by testdisk.
the real problem tht i think i fried my hdd: because in the first time, when i runned deep search, i found 2 similar results for the lost partition, and i wrote the one with the bad file system. i tried many recovery softs but most of my files are corrupeted, BUT THEY STILL THERE!
i still have hope to recover my partition, back up my files they wipe it off.
ill join the log file asap.
thank you.
Ultronium
#6 Post by Ultronium »
Tue Nov 18 23:38:37 2014
Compilation date: 2014-11-02T16:15:34
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=750156372992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=750156372992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=164532060160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=335467773952
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=215821058048
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=25037897728
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=104857600
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BEVT-75A0RT0, S/N:2020202057202d44585731344141303031323635, FW:01.01A01
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 -    Mass Storage Device
Disk /dev/sdb - 750 GB / 698 GiB -    Mass Storage Device
Analyse Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63
NTFS at 0/32/33
NTFS at 12/223/20
Info: size boot_sector 421525497, partition 421525504
NTFS at 88157/48/20
 1 * HPFS - NTFS              0  32 33    12 223 19     204800
 2 P HPFS - NTFS             12 223 20 26251 159 20  421525504
 3 P HPFS - NTFS          88157  48 20 91201  52 51   48902144
NTFS at 0/32/33
filesystem size           204800
sectors_per_cluster       8
mft_lcn                   8533
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS at 12/223/20
filesystem size           421525497
mftmirr_lcn               2
     HPFS - NTFS             12 223 20 26251 159 13  421525497
     NTFS, blocksize=4096, 215 GB / 200 GiB
NTFS at 88157/48/20
filesystem size           48902144
mftmirr_lcn               2
     NTFS, blocksize=4096, 25 GB / 23 GiB
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Failed to open $MFT/$BITMAP: No such file or directory.
Failed to load $MFT: No such file or directory.
Failed to startup volume: No such file or directory.
NTFS at 0/32/33
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/20
mftmirr_lcn               2
file_pread(5,16,buffer,59912318(3729/94/12)) ReadFile Erreur de données (contrôle de redondance cyclique).
file_pread(5,1,buffer,59912318(3729/94/12)) ReadFile Erreur de données (contrôle de redondance cyclique).
NTFS at 26251/159/20
mftmirr_lcn               2
     HPFS - NTFS             12 223 27 26251 159 20  421525497
     NTFS found using backup sector, blocksize=4096, 215 GB / 200 GiB
NTFS at 88157/48/19
filesystem size           994508592
mftmirr_lcn               2
     HPFS - NTFS          26251 227 41 88157  48 19  994508592
     NTFS found using backup sector, blocksize=4096, 509 GB / 474 GiB
NTFS at 88157/48/20
mftmirr_lcn               2
NTFS at 91201/52/51
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 25 GB / 23 GiB
file_pread(5,2,buffer,1465149440(91201/85/21)) lseek err Invalid argument
file_pread(5,1,buffer,1465149440(91201/85/21)) lseek err Invalid argument
file_pread(5,2,buffer,1465149452(91201/85/33)) lseek err Invalid argument
file_pread(5,1,buffer,1465149452(91201/85/33)) lseek err Invalid argument
file_pread(5,2,buffer,1465149503(91201/86/21)) lseek err Invalid argument
file_pread(5,1,buffer,1465149503(91201/86/21)) lseek err Invalid argument
file_pread(5,2,buffer,1465149515(91201/86/33)) lseek err Invalid argument
file_pread(5,1,buffer,1465149515(91201/86/33)) lseek err Invalid argument
file_pread(5,8,buffer,1465149184(91201/81/17)) lseek err Invalid argument
file_pread(5,1,buffer,1465149184(91201/81/17)) lseek err Invalid argument
file_pread(5,8,buffer,1465149312(91201/83/19)) lseek err Invalid argument
file_pread(5,1,buffer,1465149439(91201/85/20)) lseek err Invalid argument
file_pread(5,14,buffer,1465149441(91201/85/22)) lseek err Invalid argument
file_pread(5,3,buffer,1465149455(91201/85/36)) lseek err Invalid argument
file_pread(5,3,buffer,1465149502(91201/86/20)) lseek err Invalid argument
file_pread(5,8,buffer,1465149518(91201/86/36)) lseek err Invalid argument
file_pread(5,11,buffer,1465149565(91201/87/20)) lseek err Invalid argument
file_pread(5,2,buffer,1465151487(91201/117/52)) lseek err Invalid argument
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/20
mftmirr_lcn               2
   * HPFS - NTFS          26251 227 41 88157  48 19  994508592
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 14-Nov-2014 12:55 .
       5 dr-xr-xr-x     0      0         0 14-Nov-2014 12:55 ..
     106 dr-xr-xr-x     0      0         0 17-Nov-2014 13:37 $RECYCLE.BIN
      36 dr-xr-xr-x     0      0         0  9-Nov-2014 23:40 BOOT
      99 dr-xr-xr-x     0      0         0 18-Nov-2014 13:56 System Volume Information
      35 -r--r--r--     0      0    383786 21-Nov-2010 04:23 bootmgr
Not an exFAT boot sector.
       5 dr-xr-xr-x     0      0         0 18-Nov-2014 21:20 .
       5 dr-xr-xr-x     0      0         0 18-Nov-2014 21:20 ..
      35 dr-xr-xr-x     0      0         0 17-Nov-2014 13:37 $Recycle.Bin
   15441 dr-xr-xr-x     0      0         0 18-Nov-2014 13:56 Config.Msi
   13457 dr-xr-xr-x     0      0         0 14-Jul-2009 06:08 Documents and Settings
   44830 dr-xr-xr-x     0      0         0  9-Jan-2012 11:46 Intel
      36 dr-xr-xr-x     0      0         0 14-Jul-2009 04:20 PerfLogs
      38 dr-xr-xr-x     0      0         0 18-Nov-2014 13:44 Program Files
     210 dr-xr-xr-x     0      0         0 18-Nov-2014 13:56 Program Files (x86)
     325 dr-xr-xr-x     0      0         0 18-Nov-2014 13:42 ProgramData
   21360 dr-xr-xr-x     0      0         0  9-Nov-2014 14:45 Recovery
   90213 dr-xr-xr-x     0      0         0 14-Nov-2014 21:10 Riot Games
    1580 dr-xr-xr-x     0      0         0 18-Nov-2014 15:04 System Volume Information
     422 dr-xr-xr-x     0      0         0  9-Nov-2014 14:46 Users
     584 dr-xr-xr-x     0      0         0  9-Nov-2014 14:50 Windows
      17 dr-xr-xr-x     0      0         0 17-Nov-2014 21:07 found.000
   69393 -r--r--r--     0      0      2184  9-Jan-2012 11:49 RHDSetup.log
   58320 -r--r--r--     0      0       164  9-Nov-2014 14:49 Setup.log
   13761 -r--r--r--     0      0 4204314624 18-Nov-2014 23:27 hiberfil.sys
   17007 -r--r--r--     0      0 4204314624 18-Nov-2014 23:27 pagefile.sys
   P HPFS - NTFS          26251 227 41 88157  48 19  994508592
       5 dr-xr-xr-x     0      0         0 18-Nov-2014 15:04 .
       5 dr-xr-xr-x     0      0         0 18-Nov-2014 15:04 ..
      35 dr-xr-xr-x     0      0         0 17-Nov-2014 13:37 $RECYCLE.BIN
      51 dr-xr-xr-x     0      0         0 11-Jan-2012 00:25 EFI
   13628 dr-xr-xr-x     0      0         0 17-Sep-2014 09:32 Recovery
    5206 dr-xr-xr-x     0      0         0 11-Jan-2012 00:56 Restore
    5205 dr-xr-xr-x     0      0         0 18-Nov-2014 13:56 System Volume Information
      64 dr-xr-xr-x     0      0         0 11-Jan-2012 00:29 SystemSoftware
    4745 dr-xr-xr-x     0      0         0  9-Nov-2014 23:29 WinClon
      38 dr-xr-xr-x     0      0         0 11-Jan-2012 00:25 boot
      62 dr-xr-xr-x     0      0         0 11-Jan-2012 00:25 sources
    5199 -r--r--r--     0      0         0 24-Apr-2007 12:56 WinClon.WCL
      50 -r--r--r--     0      0    383786 19-Nov-2010 20:40 bootmgr
      61 -r--r--r--     0      0    481680 13-Jul-2009 23:10 imagex.exe
    5201 -r--r--r--     0      0 4293007160 11-Jan-2012 00:09 init.w01
    5202 -r--r--r--     0      0 4292989151 11-Jan-2012 00:15 init.w02
    5203 -r--r--r--     0      0 3295781930 11-Jan-2012 00:19 init.w03
    5200 -r--r--r--     0      0 4293002435 11-Jan-2012 00:19 init.wcl
    5204 -r--r--r--     0      0        44 11-Jan-2012 00:19 init.woo
 3 P HPFS - NTFS          26251 227 41 88157  48 19  994508592
 4 P HPFS - NTFS          88157  48 20 91201  52 51   48902144
write!
ntfs_boot_sector
NTFS at 26251/227/41
mftmirr_lcn               2
Warning: number of heads/cylinder mismatches 16 (NTFS) != 255 (HD)
Status: OK
Status: OK
Sectors are identical.
Ultronium
#7 Post by Ultronium »
PS:
my drive is
and my lost partition is
and this is the problem :
#8 Post by Fiona »
TestDisk doesn't touch any data within your partition.
It only writes partitions into your partition table and in case testdisk repairs your boot sector.
Have you been able to list your files before?
Did you run a RebuildBS?
eclark461
#9 Post by eclark461 »
Ok Once Again.
In order to really work with TestDisk on a hard drive, or anything that modifies your partition tables etc.
You must have these three scenarios before I would even begin to do anything
Your Hard Drive which is bad
A different hard drive - in which to store your critical data on
A working computer in which to run TestDisk and recover files.
I have found that sometimes after repeated attempts at writing / fixing / re-writing partitions you may wind up with some data loss. ( i myself recently lost over 3 TB of movies from a disk because I was stupid).
Ultronium
#10 Post by Ultronium »
Fiona wrote:TestDisk doesn't touch any data within your partition.
yes i rebuilt the boot sector without succes :/
